- 03.5 YLW MSP
Can this be made into a sticky for the how-to section? Yes I was board before anyone ask. I'm playing the hurry up and wait game on these computers im working on.
"How-To" Quick Links
Brakes
Annodized Brake Calipers
Paint your rusty brake rotors
Paint Brake Calipers
Rear Caliper Removal & Pad (disc) Replacement
MP3 Front Pad/Rotor Change (No 56K) (UPDATED)
Replace Front Caliper Dust and Piston Seals
Stainless Steel Brake Lines
bleed your brakes, clutch, etc ALONE!
Engine/Exhuast
VTCS Removal and Porting
FS-DE Camshaft Installation
UDP Install
Timing Belt
Install Kartboy Exhaust Hangers
Boost Pressure Tester
Painting Valve Cover
Intake Manifold Installation, Removal, Thermal Spacer Instructions
=Install Header
install Protosport Downpipe
SMIC HOW TO: Circuit Sport SMIC
Custom Cold Air Intake
remounting overflow tank with stock brackets
CP Racing STB in a P5
How to Paint Valve Cover and Exhaust Heatshield Manifold Part 1
Install GHL Turboback
change valve springs
Racing Beat rear Sway bar on P5/ES
Remove/Install Tranny and LSD or disassemble gears
How To: EGR Removal and Cleaning, Rough Idle Fix
Progress 22mm Rear Swaybar Installation
Spark Plug Install
cure Cel/Mil from removing cat with Non-Fouler
DIY filled motor mounts
Clean Your MAF Sensor
2.0 NA Header Installation
Kill your turkeys
CEL/MIL Eliminator!
Auto Tranny Flush
Install a MX-6 Rear Strut Tower Bar in a Protege5
Install a MX-6 rear strut tower bar in your Protege sedan
Change your Oil
Turbo Oil Lines
Install In-Tank Fuel Pump
AWR Rear Mount Install -- Instructions
S-pipe removal, w/out turbo removal
Body/Suspension
How to remove Vinyl graphics
Underbody Braces
Roof rack removal
Use 93-96 Mazda MX6 rear strut tower bar for a P5
Removing Back Badges and Filling Holes (mp5)
Install DG Motorsports AutoExe Replica Grille
H&R springs(on a P5)
stop the rattle in L+R rear bumpers in P5
MSP FSB Install
P5 Bumper/03.5 Lip On ES/LX
Install Autoexe Wing and Brake LED relocation
Remove Roof Rack (P5)
How do you remove The stock MSP grill?
Shaving Side moldings
Remove your 03.5 MSP lip
M6 Wagon Wiper on P5
Stop the P5 spoiler from rattling!
JDM Style Front Upper Grill
Instuctions On How To Install Tein Springs
Electrical/Interior
MSP - SS AFC Install How-To
MS3 - Install an external amp with BOSE HU (Pre-Amps)
MS3 - How to hard wire radar dectector
change fog light bulbs
Gauge cluster removal
Locked Out Prevention Circuit
Making your door locks sit flush
StreetRing Install Guide
Painting Interior Pieces
Aftermarket Seat Install (Recaro SRD)
Joe MBC Complete Install with pictures
pull Front door speaker wire...
Stock head unit with RCA outs (P5)
Swap Tachometer with Aftermarket Gauge
Want a cheap gauge pod? heres how
Greddy Profec B Spec 2 HOW TO
auto turn off head/parking lights
Gauge Disassembly
Installing Fog Lights (w/ pictures)
Haltech Max Boost Pressure Adjustment with Haltec Boost Controller
Kill Door Chime
Replacing A/C Control Panel LEDs
Gauge Dim With Cluster Dimmer
Keyless Entry Bypass
Installing different sized speakers in your car
3rd Gen Variable Intermittent Wiper Mod
Install MAM master door lock bezel
Automatic unlock doors when you pull the lever
MSP Sub/Amp Rack install on a P5
install Celica style clear bumper lenses on your P5
rewire fogs for always on
Greddy Full Auto-timer Install
Make and install your own GROUND WIRE KIT
Install an Autometer Boost Guage
1st Grounding Kit for MSP
Electric Window Mod for Always On
Install an amp wiring kit
Wire Interior Neons
Wire Fogs on a 2003.5 MSP
Water Temp gauge installation
HID Projector Headlights
Remove center Dash trim (Radio surround)
Air/Fuel Ratio Gauge install
One Touch Auto-opening Moonroof
Solution To Flickering Fan Speed 2 Or 3 A/c
Disabling Automatic A/C - Defrost modes
Tint your turn Signals (or Tail Lights)
headlight black out for P5
CANADIAN fogs on/ DRL off
install short shifter
Change Your Horn
replace headlight bulbs
P5 Rear Door Panel Removal
HKS type 0 Install
Essential Speed Stage 1&2 for your MSP
Misc
HOW-TO: Camera Mount
How-To (Forums): Post attachments!
TIG Welding Resources
Not go into coniptions due to black s*** on plastic in doors
How to read a compressor map
How to remove Double sided tape
Brakes
Engine/Exhuast
UDP Install
Timing Belt
=Install Header
Spark Plug Install
Kill your turkeys
CEL/MIL Eliminator!
Auto Tranny Flush
Change your Oil
Turbo Oil Lines
Body/Suspension
Underbody Braces
Roof rack removal
MSP FSB Install
Electrical/Interior
Gauge Disassembly
Kill Door Chime
Wire Interior Neons
Change Your Horn
HKS type 0 Install
Misc
