Mazdas247.com Your source for Mazda shift boots from Redline Goods!
Go Back   Mazdas247.com > All Mazda Tech > How-To
Notices
How-To How-To info for all Mazdas. To post a How-To thread in this Forum, please contact a Moderator or Admin for assistance.
Reply
Thread Tools Display Modes
Old 04-28-2002, 11:30 PM   #1
derrick1623
'Content Monkey'
derrick1623's Avatar
Donated: $40
ADMIN
'07 Mazda3, True red
HOW TO: change fog light bulbs
ok, i don't think this is on here, but the headlights are,so...here we go.
first, get under the front of your car, then look up towards the back of the fog light. you will see a single nut holding the fog light onto a bracket. take that and two washers off.
ok, now get out from under there(you grease monkey)...and pull the fog light out as far as you can, it dont come out far, be careful.
alright, you'll need either an offset screwdriver, or a ratchet and phillips bit. remove the two screws that hold the assembly together. pop out the glass part, and move the spring out of the way. unplug the wire ging from the bulb to the harness, and replace the bulb. ok, now put it back together, and got to the other side...CONGRATULATIONS, you've just changed your very own fog light bulbs.
derrick1623 is offline   Reply With Quote
Old 07-03-2002, 01:48 PM   #2
Jeff Cote
Registered User
Angry Change fog light bulbs ???
I'm just coming back from a trip business and I had a small accident. Actually it's nothing important but a rock broke my left fog light. So ... do you know how much does it cost here in Quebec to change just that light... 367 $ CAD not installed. So a friend of mine said that there's some «bosch» light pretty similar that will fit on my car for 175$ CAD installed. The result is so great... those lights are too powerful. They look's like the Subaru one... Actually I'm planing to doo your rewired fog lights MOD this week-end.
Jeff Cote is offline   Reply With Quote
Old 07-03-2002, 02:44 PM   #3
derrick1623
'Content Monkey'
Donated: $40
ADMIN
actually, this how to is for the bulbs themselves, the rewiring is a different thread.
__________________
Old 07-05-2002, 11:31 AM   #4
Jeff Cote
Registered User
I've found a way for the high beams
But the problem's is that I needed to do an other relay for it. And because of that I loose the control on my Fog light switch, so the fogs are always on when you turn on the lights.By the way you'll be able to see the size of the bosch lights...
Click image for larger version
Name:	fog light.jpg
__________________
Old 07-24-2002, 09:34 PM   #5
Rider69
Eagles Fan for Life
Rider69's Avatar
Florida Moderator
2007 Trailblazer SS
Sorry to rehash this old thread but...
On my P5, as I am sure most newer mazdas are, you can take the whole fog light out.
When you are taking the nut off for the foglight to come out, if you look up next to the light on the side closest to the ouside of the car, you will see the wire for the fogs. You can detach this clip and then the light could be pulled out further and disconnected from the vehicle by undoing the connection. The clip that I am talkign about is a bitch to get back on but makes for working on the lights alot easier. Besides, the clip doesn't really need to be attached again as it is not going anywhere.
__________________
Mike
Former Protege5 Owner
2007 Silver Trailblazer SS
395 HP LS2 Grocery Getter
Rider69 is offline   Reply With Quote
Old 08-19-2002, 09:43 PM   #6
1sty
Pickle Pickle
1sty's Avatar
Donated: 25$
Audio Moderator
2006 Toyota Tundra DC
Don't forget Piaa uses a P5 as their demo vehical so a few Piaa lights drop right in.
__________________
Audio Moderator, MECP certified Installer, Infocomm CTS-D certified System Designer
2009 Nissan Xterra
2010 Hyundai Genesis Coupe 2.0T
1sty is offline   Reply With Quote
Old 02-24-2003, 11:57 AM   #7
the_inkredible1
Registered User
Question changing fog bulbs
okay, now maybe i'm a moron or just really not good with cars....i bought myself some sweeeet piaa fog bulbs and i went under my car just like you said....i found the nut you were talking about, but the space by the light is so friggin cramped. do you have any pics of the tools you used while doing this or step by step process as to how you got up in there to access the light. any feedback is appreciated.
the_inkredible1 is offline   Reply With Quote
Old 02-27-2003, 01:00 AM   #8
dzack02
Registered User
there will be a little blue knob where the clip is hooked to take the whole fog light out, just push it with a screw driver and the whole thing pops out
__________________
******** Member
dzack02 is offline   Reply With Quote
Old 02-28-2003, 10:55 AM   #9
the_inkredible1
Registered User
fog bulbs
i can't check now cuz my area has about a foot of snow, but when i was under the car, i don't remember seeing a blue knob. not trying to sound like a smart ass, but is that for MP3 or for the P5? i've got the P5, but maybe i'm looking up at it in the wrong spot.
Old 02-28-2003, 11:06 AM   #10
dzack02
Registered User
take the bolt that holds the fog light on and then once you have it pulled out as far as it will go there should be a little blue plastic(you wont see this underneath the car, you take the fog light out and there it is, it is on the upper right corner of the foglight hole!
and i have a P5
__________________
Old 02-28-2003, 02:01 PM   #11
the_inkredible1
Registered User
Wink more on the fog bulbs
coo beans my friend. gonna give it a try as soon as the weather round here gets better and i'll let you know how it went. thanks for feedback.
P5's are smooooooth.
Old 03-09-2003, 02:06 PM   #12
enry
Administrator
enry's Avatar
Owner / Admin
Spicy Orange MSP & Hyper Blue Mini Cooper Soho
Stupid snow. I wanted to put in my PIAAs
__________________
Mazda Forums Administrator / Co-Owner
Problems with the board? PM ME or Antoine
enry is offline   Reply With Quote
Old 05-07-2003, 11:40 AM   #13
RAAZ227
Top Mount'in EJ20
RAAZ227's Avatar
Donated: 15$
REX -n- EFFEKT
Re: HOW TO: change fog light bulbs
I just pulled the front bumper off. 15 min. job!
__________________
*2007 UGM WRX STi*
*Former 2002 Protege5 owner*
Spool Stage 2
TiAl wastegate & bov
FS-ZE-intake cam
Mazdaspeed-exhaust cam
Mazdaspeed axle back
ACT 6-puck clutch
Groundcontrol coilovers
B&M short shifter
-Heaven-
RAAZ227 is offline   Reply With Quote
Old 05-09-2003, 02:04 PM   #14
Vicocola
Wee msp
Vicocola's Avatar
umm i left a washer out after i put the single nut back on... it shouldnt have any problems right?
__________________
#1353...
Vicocola is offline   Reply With Quote
Old 05-09-2003, 02:13 PM   #15
t3ase
Banned
Donated: $29.99
t3ase is a tease
Why take the chance? Just put it back on.
t3ase is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil change. INiTiAL33 Mazda MP3 (MazdaMP3.com) 9 12-04-2001 09:59 PM
Got New Fog Light Bulbs.. Now How in the H3LL? Mp3cHikn Mazda MP3 (MazdaMP3.com) 4 12-03-2001 06:45 PM
Gonna try and change gauge lights KurtMP3 Mazda MP3 (MazdaMP3.com) 3 11-15-2001 01:32 AM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2010, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
