Well after messing around with the wires I finally figured out how to correctly make your gauges dim with factory.... On your dimmer switch is a blue/white and a green black you can hook both wires to either. You don't have to ground them to the car.. Trust me it works.... Hope i have helped everyone... Good Luck MJG
Also if you take the ground wire from the sidemarker light and run it up to your blinker in the middle and tag the light green wire not the dark green wire your marker lights will stay on with you parking lights and blink when needed..Once again it works well.... Good Luck MJG (burnout)
