Mazdas247.com The best prices on Wheels, Suspension, Exhaust + Brakes @ WheelDude.com!
Go Back   Mazdas247.com > All Mazda Tech > How-To
Notices
How-To How-To info for all Mazdas. To post a How-To thread in this Forum, please contact a Moderator or Admin for assistance.
Reply
Thread Tools Display Modes
Old 02-17-2004, 04:18 PM   #1
PHILLY-ORANGE
0wn3d!
PHILLY-ORANGE's Avatar
MSP Orange 2003
Instuctions On How To Install Tein Springs
Things you will need are:
14mm socket wrench
11/16 socket
screw driver
spring compressers
jack
and about 4 hours of time
How to install the rear spring
1.Begin by taking off the rear deck there are 3 bolts take the nuts off all 3. (look at pic 1)
2.Take the clip off the brake line with a screw driver it just pops off.(pic 2)
3.Take off the nut that is connected to the linkage of the sway bar it's very tight.(pic 3)
4.Take off the 2 nuts that are connected to the rotor also very tight (pic 4)
5.The spring will fall out now use your spring compresser and compress the spring and take the top nut off. (pic 5)
Click image for larger version
ID:	10109   Click image for larger version
ID:	10110   Click image for larger version
ID:	10111   Click image for larger version
ID:	10113   Click image for larger version
PHILLY-ORANGE is offline   Reply With Quote
Old 02-17-2004, 04:19 PM   #2
SuperSpud
Badass
SuperSpud's Avatar
yes, but taking off the rear deck is a "how-to" of its own....
__________________
"Of all the things I've lost I miss my mind the most"
SuperSpud is offline   Reply With Quote
Old 02-17-2004, 04:25 PM   #3
PHILLY-ORANGE
0wn3d!
MSP Orange 2003
next
6.Now your spring is done (pic 2)
7.Jack up the rear to help you out on the install of the spring (pic 3 )
8.Now just put everything back together
Installing the front now
1.Take off the bolts on the shock tower in the engine bay (pic 4)
2.take the brake line off (pic 5 )
ID:	10116   Click image for larger version
ID:	10117   Click image for larger version
ID:	10118   Click image for larger version
ID:	10120   Click image for larger version
Old 02-17-2004, 04:27 PM   #4
b00sted
did you hear me?
b00sted's Avatar
03.5 Mazdaspeed Ti
__________________
2003.5 Titanium @ 10psi
~ Accub00st MBC ~ Joe P FCD/FPR ~ Spec Stage II Clutch ~ Tein S-tech ~ Hardpipes dual setup ~ Perrin sri ~ Blitz FATT D1 Spec ~ DaveB rings ~ Audiobahn 10" subs ~ PowerAcoustic Amp ~ DGM Valve Cover
~ Autometer Boost Gauge; single pillar pod ~ Flashed ~ Greddy Type-s BOV ~ Luminics Titanium White Bulbs ~ AWR Motor Mounts ~ RC 440cc Injectors ~ Custom FMIC ~ Helios HID Kit ~ GHL 3" Turboback Exhaust ~ AEM Intake ~ Kartboy Bushings/Hangers ~
======On Order======
~ Gemini Composites Reverse Cowl Hood ~ AEM EMS ~ AEM Wideband ~ AutoExe Grill ~ MAM Thumper Kit and **********'s fully rebuilt block ~ Crower Intake/Exhaust Cams
b00sted is offline   Reply With Quote
Old 02-17-2004, 04:31 PM   #5
PHILLY-ORANGE
0wn3d!
MSP Orange 2003
3.Take off the nut to the linkage of the sway bar (pic 1)
4.Take off the 2 bolts that hold the rotor(pic 2)
5.Remove the spring and compress it to remove the spring (pic 3)
6.Reinstall everything again
7. I told you that the nuts and bolts are tight it broke my socket haha(pic 4)
ID:	10122   Click image for larger version
ID:	10123   Click image for larger version
ID:	10124   Click image for larger version
Old 02-17-2004, 05:10 PM   #6
jonnydoe48
Cosmo Kramer
jonnydoe48's Avatar
if you just look at the strut the install is pretty easy. remove all bolts, remove strut. replace spring. put it back on.
__________________
Originally from CA and just moved to DFW.
Bought 6/19/03 #288 out of 2000.
jonnydoe48 is offline   Reply With Quote
Old 02-17-2004, 05:13 PM   #7
KyRaceFan
I <3 HKS
KyRaceFan's Avatar
03 MSP.
How to section here I come!
Thanks for the info, it'll be useful to me this summer when i get some tein s-techs.
__________________
2003 MSP #1130.
Intake/MBC/EBC Greens.
One of the 1st emanage MSP's till my diff exploded.
KyRaceFan is offline   Reply With Quote
Old 02-17-2004, 06:14 PM   #8
spacemonkey
Registered User
spacemonkey's Avatar
Mazdaslow
Awsome! Nice work! but there is a "How to" Section...try posting it there...maybe more helpful!
Is it possible to post pics? I wanna see how low is a 1.5 inch drop.
__________________
car: Mazda Protege
mods: eagle1 wax, nitto air freshener, E-pass, Xtreme Type R maplight, Cross Drilled timming belt
What was printed on GReddy e-manage:
Quote:
Take it easy!
"GReddy e-manage" is excellent in the generality and the expansion. And it is a low price further. Therefore, you can direct and engine too economy, easily. The Dealer of the product of GReddy of the whole country supports "e-manage". Then, you are relieved, and you can choose it. Future tunning begins first from "e".
You think this is bad try reading the instructions. Might as well be in Japanese. www.emanageforums.com
spacemonkey is offline   Reply With Quote
Old 02-17-2004, 08:35 PM   #9
KyRaceFan
I <3 HKS
KyRaceFan's Avatar
03 MSP.
mods have to move the threads there.
__________________
Old 02-17-2004, 08:37 PM   #10
spacemonkey
Registered User
Mazdaslow
There is another how to posted in the pic/vid section...mathew's DG grill install (how to).
common mods/admin...this might help someone out! This is good stuff.
__________________
Old 02-17-2004, 08:40 PM   #11
EVILSRT
Sup niggas??
EVILSRT's Avatar
MSP Moderator
2004 Black SRT
Ill move it.
__________________
2004 Black SRT-4:
AGP FMIC
AGP T3/T4 Turbo Kit
AGP Cold Air Intake
RC 750 CC injectors
Turbonetics Evolution Wastegate
Greddy Type S BOV
Exhaust Depot Hardpipes
B & B Turbo Back
Greddy 60mm Boost Gauge
Greddy E01 Boost Controller
Drive Shaft Shop 500hp Axles
Quaife LSD
Apex I SAFC 2
Apex I Turbo Timer
Stage 2 PCM
3 Bar Map sensor
3 Bar Tip Sensor
Grounding kit
Factory wheels powdercoated black
Vision Lighting H.I.D system
VIS Carbon Fiber Lip
Sprint Lowering coils
Custom Eyelids
Smoked Tails
Debaged
Quote:
Originally Posted by RyanJayG
NOT TO MENTION, my car, when done will smoke 99% of srt's out there... and look better 100% of the time (IMO)
Quote:
Originally Posted by Evil Srt
I'm the 1%.
EVILSRT is offline   Reply With Quote
Old 02-17-2004, 11:22 PM   #12
eting_pro5
Thread Killer
eting_pro5's Avatar
'03 Pro5
No one can post in the How To section (at least i can't!) The mods have to move it in there. This keeps dumb shit (such as my very own How To make cheap holiday gifts out of pop cans) from flooding this section
eting_pro5 is offline   Reply With Quote
Old 02-17-2004, 11:23 PM   #13
t3ase
Banned
Donated: $29.99
t3ase is a tease
I just tried selling a coke can motorcycle on ebay... Amazingly enough, no body wanted it..
t3ase is offline   Reply With Quote
Old 03-12-2004, 07:56 PM   #14
GearSlammer
Broke as a joke.
GearSlammer's Avatar
2003.5 Titanium MSP-TOTALED
no need for alignment?
GearSlammer is offline   Reply With Quote
Old 03-12-2004, 08:30 PM   #15
PHILLY-ORANGE
0wn3d!
MSP Orange 2003
No my alignment was fine
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: Tein S-Tech springs PROTEGE_ES This Forum is READ ONLY! 6 06-11-2004 12:59 AM
Tein S-Tech springs installed (with pics) nramsey Protegé based Rims / Tires / Brakes / Suspension 16 10-29-2003 04:50 PM
WTB Tein springs. NCMP3 This Forum is READ ONLY! 4 08-03-2003 08:24 AM
Installed w/ Pics: HKS HyperExhaust, TEIN springs, and Rota SubZeros! WannaRunThatSht Protegé based Performance 19 06-27-2003 07:39 PM
Any experience with Tein springs? Rotus Protegé 5 (Protege5.com) 0 01-06-2003 12:52 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2010, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
