Mazdas247.com The best prices on Wheels, Suspension, Exhaust + Brakes @ WheelDude.com!
Go Back   Mazdas247.com > All Mazda Tech > How-To
Notices
How-To How-To info for all Mazdas. To post a How-To thread in this Forum, please contact a Moderator or Admin for assistance.
Reply
Thread Tools Display Modes
Old 10-06-2003, 05:51 PM   #1
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
How To install Protosport Downpipe
Okay. I installed my Protosport downpipe yesterday and here's the steps I went through. The process took about 1.5 hours, not counting the time to take pictures, etc.
First, I went ahead with the check engine light fix which I got from the following URL:
http://www.apexr1.com/mamilelcfi.html
My review of the downpipe:
http://mazdamp3.com/vbb230/showthrea...threadid=33996
Now, getting to the nitty gritty. You'll need a socket set in both metric and standard measurements along with a can of Liquid Wrench or WD40. A rubber mallot could be of use, and something to remove the O2 sensor (I used a cresent wrench).
Word to the wise:
Use Liquid Wrench / WD40 liberally. Those of you with older cars are going to need to let it sit and soak in. Do not force any of the bolts, especially the ones attached to the turbo. The last thing you want is a broken stud anywhere. Take it slow, take it in one piece.
1. Get the car up. I don't have a lift, so jackstands for me.
(Doesn't my car look lovely on jackstands with only 4300 miles on it?)
Here's what you're going to see underneath. Notice the cross-member between the cats because we're going to have to work around it.
Let's get it on!
__________________
MOCC MEMBER
richelesro is offline   Reply With Quote
Old 10-06-2003, 05:52 PM   #2
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Removing the cats
2. The front of the cats are covered with a heat / debris shield. Use a 10mm socket to remove these.
3. Once the shield is gone, we want to remove the bolts shown. The mount to the transmission is going to be removed completely. That mount is held by 12mm bolts, and the cat is held to the turbo with 14mm nuts. Be careful here! Now, the large bolt needs a 17mm socket, but doesn't need to be removed if you don't want to. Read on to see what the deal is there.
4. Notice the location of the O2 sensor. This is going to be a pain later. Disconnect it from behind the intake manifold.
5. The rear connects to the exhaust with two 14mm nuts.
6. Once all the bolts are removed we have to get the cats off of the rubber mountings.
7. Now you've got the cats free from the car, except that cross-member. The best I can say is to finagle it out from the rear. The flange keeps it from being pulled from the front, and the tunnel doesn't give enough space to work.
__________________
Old 10-06-2003, 05:52 PM   #3
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Everything's out
8. Once the cats are out, it should look like the following:
From the rear, you'll see the rubber mounts. Pull those completely from the car.
The cats off the car, but with the O2 sensor still connected:
Here's another hard part: Get the O2 sensor off. I used a cresent wrench because I didn't have the right size wrench. Use what you can. However, be careful. Even with so few miles on my car this thing was a f***ing bitch to get off. Soak it in Liquid Wrench / WD40. Work it slow and try not to strip it. Good luck!
__________________
Old 10-06-2003, 05:52 PM   #4
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Putting it back together
9. Put the rubber mountings we removed on the DP. You'll notice that you have to get them around the bend on the downpipe (which is why we took them off the car).
10. Slide the pipe into place. (I did this from the rear.)
11. I attached things back up in the following order: rubber mounts, turbo, exhaust.
Let me be very clear here:
Do not, under any circumstances, over-torque the nuts to the turbo. That is the #1 cause of having to replace a stud, and you do not want to do that. Trust me.
When bolting back to the turbo, don't forget to use the factory gasket. My car had 4,300 miles on it, so I could reuse mine. That may not be the case for you, so I'd suggest having one handy if your car has over 15,000 miles.
When connecting the rear, leave this O-ring in place. The ring will mold to the downpipe's shape and prevent an exhaust leak.
When I bolted this up I noticed a gap there, but no leaks were felt. Without the ring it looked flush, but I had a huge leak.
__________________
Old 10-06-2003, 05:52 PM   #5
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
The results
Here's the underside with it installed:
Here you see the DP attached to the turbo. The highlighted bolt is the one that we removed before.
Here's the story on that bolt. The idea is to install the O2 sensor there. Now, if you install the factory one you'll have a check engine light on forever. I put the bolt in place to keep the hole plugged while I ran the engine to check for leaks. The ultimate goal is to put the O2 sensor back, but I'm going to modify it with the MIL eliminator I mentioned in my first post.
__________________
Old 10-06-2003, 05:53 PM   #6
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
MIL eliminator
12. Here's the whole O2 sensor. Use scissors to remove the highlighted shielding.
13. If you remove the piece of shielding highlighted in the previous photo, you'll see the following wires. I also included a pic of the MIL in the shot.
I'll be honest. My soldering skills suck. As such, I didn't take pictures of the next few steps.
14. Cut the blue and white wires. You've past the point of no return.
15. With the MIL you'll receive instructions on how to slice in the MIL. Note: the shielding on the O2 sensor is heat resistant so you can't burn it off.
16. For the splicing, I soldering everything together, wrapped each splice with electrical tape, and then wrapped the whole thing in more tape to get the following:
17. Finished product:
__________________
Old 10-06-2003, 05:53 PM   #7
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Putting the O2 back
18. Here's the O2 sensor connection. The thin red line notes not it's routed.
19. Try to free up the wire as much as possible. (Someone has a picture of me trying to fit my hands through those tiny spaces trying to do this.)
20. It's difficult to see in this pic exactly how I reran the wire, but I turned it back and sent it down between the two intake lines to the front of the transaxle.
This picture shows the connection from under the driver's side front of the tranny.
21. Put the O2 sensor in the allocated spot. As you can see, there's a severe bend in the wiring, and it's really close to the pipe. I'm going to try and move it a little more, but it hasn't had any signs of heat problems yet.
22. Now, with the MIL eliminator in place I started the car. Check engine light. Damn it. It eventually turned off after 4 or 5 runs with the car. Once the CEL is off, the car will run better.
__________________
Old 10-06-2003, 05:53 PM   #8
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Extra parts
These are the parts you should have extra (besides the cats):
__________________
Old 10-07-2003, 12:28 PM   #9
Geoffsurfs
traveled at high speeds
Geoffsurfs's Avatar
MSP 03
dang man. looks good! Can you tell me what kinda of difference you have noticed since you did that?
__________________
-Geoff-
MOCC MEMBER
#122
Geoffsurfs is offline   Reply With Quote
Old 10-07-2003, 12:53 PM   #10
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Quote:
Check my review at the link from the top.
__________________
Old 10-07-2003, 08:33 PM   #11
Jethro_TDot
Registered User
Jethro_TDot's Avatar
Awesome HOWTO man
Great Job Well Detailed.....
Jethro_TDot is offline   Reply With Quote
Old 10-07-2003, 08:50 PM   #12
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Thankee vewy much.
__________________
Old 10-07-2003, 09:00 PM   #13
krillin
former msp owner :P
krillin's Avatar
'05 Mitsubishi Lancer Special Ralliart Limited OZ Rally Edition
good job, james! now install mine! har har!
__________________
FOR SALE THREAD: http://www.msprotege.com/forum/showt...=119102&page=1
krillin is offline   Reply With Quote
Old 10-07-2003, 11:11 PM   #14
richelesro
Registered User
richelesro's Avatar
2003.5 BYM MSP
Install what? You have bought one yet!
__________________
Old 10-07-2003, 11:13 PM   #15
SpicyMSP
Registered User
SpicyMSP's Avatar
2003 Spicy Orange MSP & Mazda 6 S
this is my cue...
"wanna buy a downpipe?"
__________________
SpicyMSP is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Audiovox 2-way install slenser Car Audio & Electronics 5 06-18-2003 10:18 AM
Advice on new stereo install in a P5 allenpg Car Audio & Electronics 5 05-04-2003 09:46 PM
what is needed for an install slug420 Car Audio & Electronics 6 04-30-2003 10:26 AM
3" downpipe and exhaust?? Familia323 Forced Induction Tech 18 04-04-2003 08:18 AM
MAZDASPEED install.... slug420 Car Audio & Electronics 0 10-05-2002 01:23 AM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2010, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
