Locked Out Prevention Circuit
You all know the feeling; looking in through your car window staring at your keys you just locked inside.
Most likely you left the keys in the ignition, opened your door, pressed the Lock button on the door, and walked away.
There is a easy way to prevent this, and it only takes two cheap components and some time.
First the schematic. I designed this using the service manual, while my keys were in fact locked inside my car, and I was awaiting my wife to come home with here keys to unlock it.
As above: IF any car doors are open AND your keys are still in the ignition THEN your door lock buttons will not work until the keys are removed.
Any other condition and the locks work the same.
You need only a few cheap parts.
- +12volt Relay capable of NORMALLY CLOSED (N.C.) contacts.
- Silicon diode capable of handling +12volts (I used a 1N4001)
- Four wire taps
- Wire
- Zip-Ties
- Double Sticky Tape
First solder the diode to one of the coil connections on the relay.
The diode is marked with a white line, this should be towards the relay.
Leave about 6 inches of wire, and put heat-shrink tubing over the connection.
I realized later in this mod that it would be hard to follow without proper color-coding, so the above wire is later RED.
Solder another wire to the other coil terminal. Again leaving about 6 inches of wire.
This wire will later be colored GREEN
Take note of the relays schematic. We need to solder a wire to the switched terminal, and it's Normally Closed contact.
Either cut or bend the other contacts that we won't be using.
Solder a wire to each of the contacts that we left un-bent. Color coding does not matter here as it doesn't matter which connection goes where at the other end. Leave about 4 or 5 feet of wire.
Here you can see my RED and GREEN wire change.
The circuit is now ready to take out to the car.
I also included some zip-ties and a piece of double stick tape.
