MPNick said:
clamp is only one part of the total holding of the clutch setup. The clutch face also play a very important part of the total grip. Then you also have to look at the life span. A lot of time the stock clutch set up will out last the aftermarkt high performance replacement.
You will burn the stock clutch disc up faster if the pressure plate doesn't clamp the disc down. Clutch slipping occurs when the pressure plate can't clamp the disc down. This is addressed with the higher clamp load capacity of the pressure plate.
The disc is upgraded in conjuction with spring hubs to reduce drivetrain shock and impact compared to the stock rubber torsion dampers. On the MSP the disc has 6 while the regular protege has 4. The organic friction material on the Exedy disc is higher quality than the OEM specs and are more resistant to burst and slippage compared to OEM. You can see the difference in the material when compared to a stock MSP disc. Exedy's performance division ante's up the disc for performance and reliability.
You are wrong to assume this clutch will not hold and last as long as the stocker. The stocker will burn out faster if it is slipping due to the higher torque output of modified cars. This clutch exceed's the stock specs in everyway. I worked with Exedy to test and develop this clutch for the street. It is daily driveable and responsive when used for performance oriented driving for higher output cars.
With the Exedy everything is ENGINEERED to exceed the OEM clutch. Daiken clutch which makes the OEM clutch for the MSP and Reg Protege also makes Exedy. Daiken clutch supplies most of the Japanese manufacturers so you know they are up there with manufacturing quality, especially when other aftermarket brand clutches use their discs, ie. Spec, Act. Exedy also supplies new Japanese KOYO bearings which are also OEM. Nothing was compromised.
The driver is the variable that determines how long a clutch lasts. If the clutch doesnt hold it will burn up just as fast if someone really beats on their clutch, i.e. not rev matching, clutch slips, clutch riding, etc.
