ok, so im planning on big numbers. im ready to put into it and im ready to get everything this car is capable of
currently, my car is on blocks getting the motor removed. ive had the car for.. almost two years now and ive done a few modifications myself..
as is, im making 226whp with the following
fmic with 2.5" hardpipes
relocated turbo with custom made exhaust manifold
HUGE 3.2" downpipe with electric exhaust cutout
short ram intake
aem boost control/gauge in one
plugs/wires
split second air/fuel timing controller
maximum stiffness engine mounts
for me.. i think that last bit i put into the car was childsplay, but its a good starting point because i have all my gauges, fmic, and downpipe with cutout
now for the plans.. oh im excited
first off the engine is coming out and im going to get it honed, bored and ported and polished
wiseco 9.0:1 pistons
K1 rods
CS exhaust cam
adjustable cam gears
racing v/v springs
(complete engine overhaul kit already here)
universal oil cooler
electric boost control for more reliability over the AEM gauge
600cc injectors
fuel pump
T3/T4E Turbo
fidanza flywheel
ACT 6puck stage 3 clutch
full set of lightweight pulleys
i have ssaf/tc but im going to ditch that damn MAF and ss and probably going haltec
now. to my questions.. i want yall to be ultra critical..
i know a few things are left out like clutch lines and brakes and whatnot but for the most part these are my main buys. but i do have a few critical questions
since im getting new pistons im going to get the block bored, is there advantages of going .020 versus .040?
I dont have any problem with creating manifolds/downpipes/mounts or anything of the sort - i have all the capability and machines i would need to do it.. but i am stuck deciding exactly what i want to do, because i want it to be really unique
i see 3 options..
1- one large turbo. normal setup
2- two turbos, compounded, manifold into one turbo, then ex of that turbo into the intake of the next turbo
3- my most preferable option but i am stuck on whether or not its possible.. compound charging a turbo and supercharger.
i really want to explore this, and already have.. but am curious.. if i get a roots type blower, does it mount ontop of the valves? i dont understand where the damn thing sits in the engine for it to give the air charge, run oil, and be connected by the belts..
ANY input is considered helpful even if you say its not a good idea.
do any of my items in my build clash?
am i missing anything big? who has bought the new gears for the tranny? are the worth it?
short ram intake
plugs/wires
K1 rods
CS exhaust cam
racing v/v springs
600cc injectors
fuel pump
T3/T4E Turbo
fidanza flywheel
i see 3 options..
