You sure you can boost your engine with 13-1 compression because Mazda couldn't. Read here about Mazdas new turbocharged 2.5 with 10.1 compression. http://www.automobilemag.com/features/news/deep-dive-inside-the-mazda-skyactiv-2-5t-turbo-engine/
You sure you can boost your engine with 13-1 compression because Mazda didn't. Read here about Mazdas new turbocharged 2.5 with 10.1 compression. http://www.automobilemag.com/features/news/deep-dive-inside-the-mazda-skyactiv-2-5t-turbo-engine/
FTFY.
I read somewhere that Mazda tried very hard (and succeeded) in avoid wasting fuel on rich combustion under high load with the new engine. Mazda also worked hard to make the new engine efficient under high load.
Chris just wants some extra power and a fun project to work on and likely doesn't care much about efficiency.
Obviously he isn't going to see 310lb/ft of torque at 2000RPM, but by injecting some extra fuel and running rich, it'll definitely be possible to run some boost.
Man I love looking at these old posts that talk about can't do this can't do that, and then it's been done.. multiple sky's have been boosted as far as I know up to 7 psi. One motor was 90whp gain at 5 psi. Same thing with availability of aftermarket parts, which for the cx5 there are many many
And then there are others that spun a rod bearing trying.
Chris, what is going on with your engine? Any updates?
