- 2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
Through our partner ship with BEGi, we'll be sending a willing volunteer to thier shop in texas to fit and tune a Vishnu XEDE engine management system to the Mazdaspeed6. ProtegeGarage will be the exclusive reseller for XEDE systems on these cars and the results are promising.
Fitted to a Mazdaspeed3, this system gave the car a whopping 290whp and 310lb/ft of torque on the dyno with no other modifications. The system has been used to great effect on the Mazdaspeed Miata and we expect the same from this system on the MS3/MS6. From BEGi's miata features and descriptions;
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]The [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] is the most user friendly engine management available! It plugs directly into the stock ECU and requires no tuning. The [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] comes pre-programmed for your application.
[/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]How does the [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] work?
It is wired into a wire harness that plugs into the stock ECU. It intercepts signals to the ECU. For example, by intercepting the crank signal, the [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] can advance or retard timing. By intercepting the load signal, the [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] can make fuel mixtures richer or leaner. It remains under closed loop during idle, and goes open loop under boost. [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]The MazdaSpeed Miata (MSM) [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] also allows the user to control the boost levels.
Installing the [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]....
This is probably the easiest aftermarket performance part you will ever install on your car! The hardest part is installing injectors, and that too is not difficult. Once the injectors are installed, plug the [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] & wire harness into the stock ECU. Turn the key on. Turn the Key off. Start the engine. Rev the engine, watch the LED light turn green, and you are ready to drive. The MSM requires a new wire installed to the boost solonoid. It's so simple, even Stephanie could install the injectors and figure it out! No broken nails either.
Practical Information...
What is more practical than get in and drive? Forget tuning the car every time you drive it or the weather changes. Short of getting struck by lightening, the [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] won't fail. It will be the most reliable piece of hardware on your car.
The[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] cannot change the rev limiter on any Miata.
The [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] can be used on ALL Miatas.
The MSM [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] will illuminate the check engine light. It changes the stock ECU boost and TPS signal. [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]Please contact us for more information[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] on OBDII inspection. Black tape covers the CEL. The MSM [/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] comes with 440 cc Injectors.
The 1999+ turbocharged and supercharged Miata's have passed OBD II and Emission Inspection in Texas.
The Xede has been installed on the 2006 MX-5!
[/FONT][/FONT] [FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]XEDE[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif] Technical Specifications
[/FONT][/FONT]
[/FONT][/FONT]
[/FONT][/FONT]
- 1200 possible adjustments
- 0.1% accuracy on MAF, MAP, and TPS adjustments
- 0.1degree accuracy on timing adjustments
- Direct plug-in wire harness (no cutting or splicing required)
- Fully sealed, rugged, and lightweight housing
- Support for hall and reluctor type crank and / or cam timing signals
- Support for analog or frequency MAF and MAP / load signals
- One additional 10-bit analog input
- One auxiliary digital input / output
- Internal storage space for up to 12 tuning maps
- Built-in boost control (MSM only)
- Built-in knock signal adjust feature (MSM Only)
- Self-configurable load axis, input and output variables, adjustment range, and math function for each map
- 'Map Select' input to change between one of two unique tuning maps
- Bi-color status LED
