- 2003.5 Titanium Gray MSP #1699
I'm pretty sure that John already said in the other thread that the exhaust is J-pipe back...same thing I have now.
ONRAILS said:How much is your fmic, and will there be an option to keep the stock bpv setup, and have the pipes in black, or not coated at all so they can be powder coated?
mazdamp3_18 said:whats pricing on the full exhaust...
Doesn't AWR make a narrower radiator for the MSP that allows room for the SMIC but is also thicker for better cooling?mx3ownzj00 said:Thanks for the reply. I wasn't so worried about putting in a higher flow radiator as I was just replacing the smaller MSP unit with a regular(larger) Protege radiator.
got that from here: http://www.axronline.com/store/products/Mazda/Protg/Radiator/Antony-Woodford-Racing/0000-01-3501-Antony-Woodford-Racing-HIGH-PERFORMANCE-RADIATOR-1995-2003-PROTEGE-SEDAN,-MP3-AND-PROTEGE5_4410114.htmlFor MAZDASPEED or turbocharged applications, we offer a thick core option, which is 6" narrower to allow for the placement of an intercooler or oil cooler beside the radiator.
If the FMIC is the one John showed in the other thread. It appears it goes around the whole where the SMIC was....mx3ownzj00 said:For your Front Mount IC, does the charge/cold pipe route through the empty space opened up by the removal of the stock side mount IC? My only concern is the ability to upgrade to a larger radiator.
What's that mean Vic?Dr.Sound said:^ ehh, no.
LMAOBlack Majik MSP said:What's that mean Vic?
I'm more curious to see how the hot pipe fits through on the left side.
I'm just not sure if it leave enough room, etc. I'll have to get off my ass and compare dimensions one day. I think that one is a bit thicker too. I dunno about turbo clearance etc. Also more expensiveBlack Majik MSP said:Doesn't AWR make a narrower radiator for the MSP that allows room for the SMIC but is also thicker for better cooling?
PERRIN_JOHN said:I do not. I will see what I can do. I see you linked to a picture on Vivid racing.com. MSRP is 159.99, though I think Vivid sells it for less. Ask your local dealer.
Our MAZDASPEED product lines have not officily been released. As soon as they are all links will work.
Yes, we do have a fuel rail and it will require no cutting or special adaptors. It will directly attach.
