benben84 said:
Ok, well lets say my goal is to get 350whp. Will the tranny upgrade and everything else handle that? I would probably hit high horsepower numbers on a dyno and at the track one time just for bragging rights and then run the car normally at 250-270whp daily.
I didnt post this here to fight with some closeminded persons.
Ill try to make this as complete as possible. This is what you will need for 350-400hp and daily driver.
Bottom end.
forged pistons (go a little high maybe 9.1)
Billet Rods (oliver)
Upgraded rod bearings
Billet and balanced crank (MAM's is good)
ARP fasteners (for everything)
Tranny
Clutch
Flywheel (not nessesarily lighter but a stronger compound like chromoly)
Upgraded syncros
Ugraded LSD
Upgraded spider gears
Upgraded fluid that can withstand the high temp
Tranny oil cooler
Stronger axles and driveshafts
Stronger knucles
Brakes You need to stop the car ya know
A good setup (doesnt mean a BBK!)
ECU
Good standalone like a Microtec or AEM
3bar Map sensor (i would go with Motec)
Fuel
Pump ( popular brands like walboro will do)
Fuel rail with a fuel return
Upgraded FPR
Upgraded fuel lines
550+ high imp. injectors
Turbo
GT30rs or equivalent will do
Upgraded manifold
Upgraded pipes (plastic doesnt cut it)
Upgraded FMIC (not some cheap kit)
Upgraded BOV
Suspension
I would upgrade but that is your buisness
Tires
Some good tires that are streetable and kinda soft so you can try to put the hp on the street.
If I missed anything someone pleae add.
