twentytwocpb
- Mazda Protege MP3
ok cool. what about the coil pack? does it have to be from a 2000 Protege 1.8L or can it be from a 1.8L Miata? if so what year?
i'm not 100% sure if the miata coil has the same harness connectors.
Same here on condensor mounting.......
i never understood the point of this "mod"
lets take a better design by having the coil right on top of the plug like every performance car in the world has, you know so there is way less resistance because the spark has way less distance to travel, and go back in time to an old less efficient way.
If you really want to improve things, the only thing you should use off of an old 1.8 is the plug wires. And not the crappy stock ones but a set of really good aftermarket ones. Then get yourself a really good 4 post MSD coil or even better an MSD coil and an ignition box and actually improve your car and not go back in time.
I agree with you completely. I also don't see how moving the coils to above the exhaust mani is better then on top of the valve cover, to me it's worse.
i upgraded because i had a bad coil, and at the time, it was cheaper to go with the 1.8 set-up. i have no regrets.
There is no proven HP from it. It looks cleaner to some people and some (like myself) got sick of replaceing the coil on plugs all the time and this has solved the issue. If you are that interested in numbers, do a before and after dyno would be the only way to tell.
