I am a long time Amsoil user and still utilize it in my other cars and powersport equipment (snowmobiles & ATVs) but the Mazda moly oil ratings and threads on Bobistheoilguy has compelled me to use it exclusively on this Mazda. It's cheaper than the Amsoil I had originally intended to use.
http://www.cleanmpg.com/forums/showthread.php?p=357910
I didn't use that over priced, overly hyped mazda oil; I used penzoil pure (got it for around $3 a qt) and it worked well. Ho do I define "well"? I posted the uoa of it. It was the first oil change so iron was slightly high (Blackstone said that was break in residue, it will take a few changes to get rid of it) but otherwise excellent. I have yet to see an uoa of Mazda oil doing a better job. Blackstone said to go 10K miles on this current change of pennzoil before sending it back for a uoa.
Can one consistently get a cheaper price on this Penzoil alternative as this is basically the same price as Mazda oil? Rebates won't always be available when you need it.
https://www.amazon.com/dp/ (commissions earned)
It may actually be a little more expensive as this doesn't include a filter.
I can get it from dealer for around $7/quart and that is cheaper than the Group IV Amsoil I was going to utilize.
I've heard good things about Redline products and issues with Royal Purple.
Whatever you use I wouldn't give dealer an excuse to deny a warranty claim and stay with a 0W-20.
Looking back, I did use 5-20. I think the manual says you can use 5-20 though. At any rate, that Mazda stuff is over priced. I was at pepboys today and five qts of penzoil synthetic and an oil filter was $20. With the oil filter, that's about $3.50 a qt. At that price, I fail to see the reason some will pay double or triple for an oil that has not been demonstrated to be any better or even as good.
Even without rebates and offers, still probably cheaper as Mazda oil in my area is around $10 a qt, waaay too much for oil. I can get Redline 5-20 for around $7 a qt from a wholeseller which that too, is likely better than Mazda. Want a lot of moly? Redline has it. Want a real synthetic, not a group III? Redline is made with ester/pao.
I think without coupons and deals, the most I have seen it go for is $9 a qt. I think Walmart has it in a jug for less.
0W-20 has low viscosity. Mazda, along with several other car manufactures, recommends it because it will lower the friction threshold in the engine which will in turn give you better MPGs.
It doesn't much matter to the engine if Redline is made from virgin unicorn tears, the engine responds to it's measurable properties, not what it started out as. A few thoughts on your comments:
Mazda GF-5 0W20 is over-priced? And then you compare it to an oil Redline 5W20 that has much higher cold start viscosity than desirable. First off, how do I purchase it for less than the Mazda GF-5? Please provide a link because a quick check shows most retailers selling it above $11/quart. Secondly, why not compare it to Redline 0W20, an oil with much more favorable cold start viscosity and more comparable to GF-5? Redline 5W20 acts more like a 30W oil in terms of cold start viscosities.
The cost of Redline 0W20 (comparing like viscosity ratings) is at least as expensive as the 5W20 and much more than the Mazda GF-5. Even buying it by the 55 gallon drum it's over $11/quart at the only place I saw offering it in bulk. I can get the GF-5 shipped to my door for under $8 in convenient quart bottles last time I purchased some. And I like that it's not over-loaded with zinc. For some reason Redline thinks if a little is good, a lot must be better. Zinc is very inexpensive, I doubt other oil manufacturers use far less zinc to save a fraction of a cent. It looks to me like it's the Redline that costs more than most people want to pay and yet that's what you slam the GF-5 for.
Makes no sense.
