- State of Jefferson
- 2017 CX-5 GT AWD+
I have had many Mazda's where the A/C compressor clutch is disengaged at WOT. I do not find it strange at all, just gives you less parasitic drag on the motor. Especially noticeable when you have a motor w/ around 100hp. If you are still WOT when A/C re-engages, you can certainly feel it.
There is even an error code for when the WAC system is malfunctioning...
P1460 MAZDA - Wide Open Throttle Air Conditioning Cutoff Circuit Malfunction
It DOES make perfect sense. It would even make sense to me if there was a "Half Open Throttle Air Conditioning Cutoff Circuit". I ALWAYS turn off the AC if I need max power, it's a HUGE parasitic drag.
Mazdadude, if there IS a WOTACCC, how could this happen: "If you are still WOT when A/C re-engages, you can certainly feel it." ? If it works, the AC wouldn't reengage.
I'm just looking for confirmation. Anchorman's AC pdf made no mention of a WOTACCC.
