As I've said before, there is enough warning notice to not worry about it aka red light comes on, pull over straight away
I would rely on the light anyway as I rarely have the temp gauge showing. The only time I hear of overheating these days is when the coolant is lost.
So I ran a test. Plugged in my OBDII and went for a drive with the service screen and temp gauge selected.
Once OBDII was reading 190 the temp gauge on the dash had reached the middle which is labeled as 210.
The OBDII was at 190 for several miles of driving at 45 mph at about 95 ambient.
Once we encountered traffic it rose a bit to 195. Then once at a light it came up to 197 briefly then dropped back down to 195. Stayed there until we got to open road again and dropped to 192. Once we reached our destination it was at 194.
This entire time the dash gauge didnt budge after reaching 210.
Empirical evidence based on observation of actual behavior.
I wouldnt call that gauge accurate. I think it indicates engine is cold, warming up, at operational range, or overheating. Not real time accurate readout.
I feel like I’ve offered proof that it does artificially go to the middle at a temperature labeled that doesn’t correlate to actual readings.
Do you have any counter evidence either documentation that it’s supposed to be an accurate real time readout or evidence from observation?
My opinion here is that the cooling system while it’s great and all can’t just instantly react and hold the temp precisely. And honestly that isn’t even necessary. It’s quite normal to fluctuate within a safe range. They just don’t show this to the end consumers as it’s 1 not necessary and 2 just tends to lead to people worrying because it went up a bit when they climbed that hill or whatever and complain when it’s all perfectly normal and nothing is wrong.
And as others have said pretty much ALL modern cars do it and a lot don’t even bother with a gauge at all.
The scenario I read was back in the very early 1990's about the then all new GM Holden Commodore. It was in the outback of Australia, 40 day, going at 110km/h and the motoring magazine tester/reviewer floored the GM Holden Commodore V6 to reach the max speed of 208km/h and then hold it there. The duration of time from memory was atleast a few minutes to reach maximum speed and then was held there for a few km. This was back in the day when there was no speed limits.
During this test, they noticed the air conditioning starting to blow hot air and not working as intended as power was being essentially diverted to maintain acceleration and velocity.
The above scenario in 99% of driving cases, will not be achieved by the average owner in normal day to day vehicle use. Even running short tests would more than likely not trigger it.
It should be noted exotica would probably not experience this scenario as they would be able to maintain air con temperature at high speeds and sustained acceleration.
"Do with it what you will"
X8, you may like this. I’ve found some info that suggests that there is indeed some suppression of the AC under acceleration. Not quite what we were discussing but the fact remains! So for the diesel, the AC is inhibited for the first 5 seconds of throttle over 60%. The gasoline is slightly different in that it is inhibited for the first 5 seconds from rest but not linked to hard acceleration. Like I said, not quite what we were discussing but interesting nevertheless.
I feel it in ours every now and then. 5 seconds is probably short enough for that the coil remains cold enough for it to not be too noticeable in most cases.
The thing is typically when I notice it is shortly after passing or farting into a hole in traffic where I’m at or near WOT.
Damn auto correct
Most new cars do that to keep average consumer worry free.
Our CX-5 does not have a temp gauge so I use OBDII from time to time to check the temp because I'm weird like that.
Back to the original question before all this got out of hand: The AC on my CX-5 might not be freezing cold in some situations but it is definitely comfortable and fast enough. The high humidity here in Panama pays a huge deal on this, removing all that humidity from the cabin is a hard task.
And they don’t use the solar blocking glass like some auto makers do. This is probably a big factor.
