True I think the goal is to catch it and take action before that happens.
The blue light will come on. That is the indicator telling one to pull over.
Blue means cold and red means hot.
Most older cars I have driven don't have their gauge fluctuating. Should only move higher when there is an issue.
The CX-5's should be the same.
So I ran a test. Plugged in my OBDII and went for a drive with the service screen and temp gauge selected.
Once OBDII was reading 190 the temp gauge on the dash had reached the middle which is labeled as 210.
The OBDII was at 190 for several miles of driving at 45 mph at about 95 ambient.
Once we encountered traffic it rose a bit to 195. Then once at a light it came up to 197 briefly then dropped back down to 195. Stayed there until we got to open road again and dropped to 192. Once we reached our destination it was at 194.
This entire time the dash gauge didnt budge after reaching 210.
Empirical evidence based on observation of actual behavior.
I wouldnt call that gauge accurate. I think it indicates engine is cold, warming up, at operational range, or overheating. Not real time accurate readout.
Yes but that was a sports car. Here most vehicles as in family cars only had temperature and fuel gauges and as mentioned, temperature gauge didn't move that much. I'm talking family cars here from 1970s and 1980s.Having owned vehicles that had real gauges, I strongly disagree. My Z06 would show coolant as well as oil temps digitally to the very degree, and they fluctuated depending on speed, acceleration, temp during the commute, all manner of things.
I didn’t even go WOT. That certainly would have raised the temp a bit more! I’ll try that this weekend and see what it does.
Would not the computer system put the engine into protect or limp mode if the temperature got to a certain point?
