When the transmission of my 626 started to die, I replaced it with this little beauty:
I made one judgment error, however. I thought I could live without a manual transmission. I considered upgrading to a MS3, but could not resist the vtec.
On August 7th 2008, I fell in love . . .
As soon as I parked my car for the first time, I performed my first moddealer sticker delete.
August 7, 2008Second mod! Ipod intigration!
August 11, 2008My Si went to the tint shop and had HP Supreme Solar Gard window film from Bekaert Specialty Films installed:
Front 50, Rear 30, Rear and Moonroof 20
August 15, 2008I just couldnt take the premium sound system anymore and installed:
Alpine SPS-500 Type-S 6-1/2 Fronts
Alpine SPS-500 Type-S 5-1/4 Rears
Elemental designs 9Kv.2 open air sub
Alpine MRP-F300 50W x 4 Multi Channel Power Amp
August 16, 2008Set up a temporary fix for the vtec + groceries issue.
August 18th, 2008Cleared out headlights.
September 28th, 2008civic delete
October 4, 2008Trunk, map, and dome LED swap.
Cool white LEDx5 swap for the license plate.
White 9LED festoon bulb swap for dome and map lights.
Cool white WLEDx6 bulb swap in trunk.
Purchased from SUPER BRIGHT LEDS
October 13, 2008My Si met a professional photographer.
October 16, 2008--K&N 69 Series Typhoon Air Intake installed!
November 12, 2008--Progress 22mm Rear Sway Bar installed.
November 14, 2008Attended first civic meet!
November 26, 2008Redshift Rear Sway Bar Reinforcement Brackets installed.
November 27, 2008Replaced transmission fluid with Red Line MT-90 Synthetic
November 28, 2008Cargo net and Trunk tray installed.
December 10, 2008--Kenwood DNX8120, SCOSCHE dash replacement kit, PAC SWI-JACK steering wheel control interface, and BOYO VTL400 Rear View Camera installed.
December 14, 2008Focal 165CA1 Coaxial speakers installed.
December 15, 2008--Finally got rid of terrible layer of funk on the inside of my windshield (No, I didn't do it. It came with my car.), installed GrafiXpressions emblem, replaced fugly license plate screws with small, clean anti-theft ones from Autozone.
You can see the problematic place where my backup camera is installed here:
December 18, 2008--Dirty loaner valve cover arrived in mail.
^ ewww, right?
1st mod=cleaning:
Took mine off:
And installed temp.
December 19, 2008
Pried those little plugs out of the valve cover.
I ordered a special red for my valve cover and shipped it off.
December 20, 2008
Installed my new JDM hazard button and rewired nasty mess of wires behind the poor Navi.
December 30, 2008
Installed HFP suspension! Without the "right" tools, this can take seven hours. Seven hours with small dinner break.
FYI! Despite what it might look like in this pic, my foot is NOT on the rotor here. I'm pushing a wrench. Carefully.
Guess what? Suspension upgrades are fantastic. Now I can REALLY feel a difference. (And, yes. This is exactly the suspension I want, so I will not be lowering any more or installing coilovers or anything.)
December 31, 2008
Began damper install
So . . .
And then three people tried to use the horrible rivet gun for over an hour. Working different combination of bracing the hood and even squeezing the gun in pairs. NOT fun!
But, FINALLY!
But we didn't have the right drill bit for the bottom, so project is being continued . . .
January 1, 2009
So I bought a $40 drill bit, but that's ok. It'll be useful for many projects in the future.
Drilled all kinds of holes in my car:
But it's worth it.
It sucks taking out the stock hood prop, but the engine bay looks way better without it.
January 6, 2009
The HFP front lip comes in a HUGE box!
It and your front bumper are a little awkward to maneuver.
You should enlist the help of some friends.
Your car will be happy when you are done.
January 18, 2009
So, I preordered an engraved, weighted shift knob. In the mean time, my short shifter and base bushings have been sitting on my shelf for a long time. So . . . I haven't modded my car in awhile. And . . . I started thinking--after installing all the shifter components, how will I be able to distinguish which is making the biggest difference?
So I have decided to do my install in shifts.
Today, I installed the base bushings.
WOW! What a difference! Talk about control! Everything is now so much more mechanical. Each gear is much more distinct and solid. Now I have to resist resist with the short shifter. I have to get used to these bushings first
January 19, 2009
After being stuck in traffic for over an hour on my way home from my run, I felt that I had give the base bushings a suitable trial run and decided to install my TWM short shifter. Compared to the bushings, which were not all that difficult, the short shifter itself might be the easiest install I have performed thus far.
(Sorry for the iphone pic, I forgot my camera.)
Only one complication spoiled what would otherwise have been a flawless install: Before reconnecting the shift knob, bolt, and boot, I decided to give the new shifter a try. In a wave of panic, I realized that I could not find fifth or sixth gear! I screwed the knob on and continued to panic, finally calming myself, putting my car back together, and starting it.
Suddenly, fifth and sixth gear resurfaced and I quickly got used to the new feel. This was not nearly as dramatic a change as the base bushings provided, but it's still nice. I'd be interested to see how it compared to that Mugen quick shifter.
January 21, 2009
A k20 valve cover came to visit from powder coating camp. After removing my loaner valve cover, I noticed that it was not only NOT my original cover. It was not even from a Si.
My oil dropped to 15%.
January 23, 2009
The imposter valve cover started its return voyage to powder coating camp, and I made a quick run to AutoZone.
I can now barely drive up ramps with my HFP suspension and lip.
Removing the drain bolt was simple! Nothing like the transmission fluid bolt!
Removing the oil cap took some effort, however. Oil drained and the real fun began.
Reaching the filter is not the difficult part! Using a crappy AutoZone tool is! After realizing that no amount of shop towels was going to make the tool quit slipping, I got on the phone and asked a local civic how he had removed his OEM filter. He arrived with his mystery OEM removal tool, and it was smooth sailing from there on out. The top of my new K&N filter fits a 1" socket, so it'll be simple to remove when the next change rolls around. By the way, Royal Purple oil is actually purple.
January 16, 2009
Installed Mugen radiator cap. Jay-Dee-EMMM (2thumbs)
January 31, 2009
Exhausting work today! Ugh.
My new "hi (flow) cat" GReddy EVO@ exhaust!
Even with WD40, the stock exhaust is horrid to remove.
February 3, 2009
Back to stock exhaust. Whewh. I'll do better the next time around.
February 6, 2009
Dual car party tonight. The guy that bought my EVO2 came over, and he installed it on his coupe while I swapped out my valve cover.
Well, it is still not my valve cover, but, hey! Acuras are cool cars too.
I did this swap in less than an hour! I'm learning!
February 13, 2009
So, I wake up as giddy as a kid on Christmas Morning! It's Exhaust Day!
At 7:00AM, I refresh FedEx's site. Again at 8:00. 8:05, 8:06. . .8:48! Info is updated!
WTF?
You know their number is difficult to find, but I get online and call everything in my city with FedEx in the name until I finally get through to a representative with a thick foreign accent who gives me the address of the facility holding my poor package hostage.
I jump in my car and vtec down to the office.
The guy behind the desk is all kinds of confused.
"That's weird. It says here we are closed for a holiday. . ."
I wait about 20 minutes, then they wheel it out.
Translation! "Closed for holiday" means "Our truck is too full for your box."
After wheeling it out, all the employees scatter, and I quickly realize why.
Next time I drive to FedEx, I'll bring scissors. (rant)
But, hey. I managed.
SOOOO Hawt!
The install was clean and simple.
And it looks nice and subtle:
Many more mods to come!
^ ewww, right?
1st mod=cleaning:
Took mine off:
And installed temp.
December 19, 2008
December 20, 2008
December 30, 2008
December 31, 2008
So . . .
But, FINALLY!
January 1, 2009
But it's worth it.
January 6, 2009
January 18, 2009
January 19, 2009
January 21, 2009
January 23, 2009
January 16, 2009
January 31, 2009
February 3, 2009
February 6, 2009
February 13, 2009
WTF?
SOOOO Hawt!
