UKtheGREAT
- 2003.5 MSP
Sure. I would imagine the ECU has detected a WOT condition, and has reverted to that portion of it's "script" as a default, more or less.
In short, our ECU acts like a narrowband when it comes to fuel delivery. It reads either lean, stoich or rich. If you are crusing along it will maintain the stoich 14.X AFR, but once the ECU reads any amount of boost it will dump a set amount of fuel because it does not know how to measure exactly how much fuel needs to be added.
Like an O2 voltage clamp? That's exactly what the SSAFC does.To bad we can't just trick the cars to go into open loop 100% of the time. It would make tuning these cars a breeze and making them more consistent.
Not sure to be honest with you. I haven't read up on 02 voltage clamps and how they work. On the SSAFC does the 02 clamp fool the ecu into going into open loop on any sign of postive presure?Like an O2 voltage clamp? That's exactly what the SSAFC does.
You can set the AFC to kick on at whatever pressure you want, mine is at -1psi.Not sure to be honest with you. I haven't read up on 02 voltage clamps and how they work. On the SSAFC does the 02 clamp fool the ecu into going into open loop on any sign of postive presure?
For the record.. I'm trying to crack the Ecu with a tactrix cable
A friend of mine who is a Nissan tuner has suggested to me that we use a SR20-DET computer, since they can be tuned easily, and wire a jumper harness in-between our harness and the SR20 ecm matching the pinouts with the correct functions and such....not sure what kind of crank trigger they use i guess they would have to be the 1 missing tooth design like ours...
But could this work?
