Hi everyone,
I'm new around the forum, but not new to the rotary market. I thought I would introduce an ECU brand that is really starting to take off in the rotary market, and really outshines the past popular brands. You can buy these units from Tri-Point Engineering, a forum sponsor and Adaptronic Dealer;
http://www.mazdas247.com/forum/forumdisplay.php?293-Tri-Point-Motorsports
This Adaptronic ECU is the most Advanced Plug & Play ECU on the market for the Series 4, 5, 6, 7 & 8 Mazda Rx-7.This Adaptronic ecu uses VE Tuning, Fully Automated Injection Staging, and Adaptive Closed Loop Self Tuning. Combine all of these advanced features plus many more listed below with bar non tech support, quality base maps & wiring schematics, and you will be on your path to a properly controlled and tuned engine!.
Adaptive Close Loop Self Tuning is a system designed by Adaptronic to not only trim the fuel & ignition maps, but automatically edit the base values, and perform " self tuning ". The unit also does the same for idle control, and transient throttle( throttle response). See the YouTube video below for more information.
Volumetric Efficiency Tuning uses internal algorithms to deliver a more accurate & linear tune twice as fast as millisecond tuning by combining injector size, injector dead band timing, swept cylinder volume, and RPM to calculate engine fuel demands. Some ECU brands advertise VE tuning, but they aren't compatible with staged injection found on the rotary engine. See the Youtube video below for more information
Fully Automated Injector Staging means you never have to worry about tuning the injector transition again. This car be hard for novice tuners when there is a larger difference between primary and secondary injectors. No matter size injectors you have the Adaptronic does all of this flawlessly on its own.
Multiple tuning modes including Volumetric Efficiency for accurate & easy tuning.
Advanced Adaptive Fuel & Ignition Control including 100% configurable tolerances, loop gains, & conditions for automated AFR, IDLE, & Transient Throttle Control( Closed Loop Self Tuning).
Full Sequential Fuel & Ignition Control- Direct fire capable( 4 individual coils), and Individual Rotor Injector Trim
OMP & Stock Sequential Twin Turbo Control
Internal 4 bar MAP sensor for engines running as high as 40 psi of boost.
Advanced Engine Protection Features- definable rev limiters for engine lean out, low oil, fuel or auxiliary pressures, etc.
Traction & Launch Control configuration.
Integrated 3.5mm headphone jack for real-time listening to knock
E85 Flex Fuel Control for maintaining accurate injection rates utilizing real-time ethanol content monitoring. (Requires Flex Fuel Sensor like GM or Zeitronix)
Built in Boost Control Software including Boost by Gear using OEM transmission sensors
Spare 0-5v analogue input, one spare aux output, 3 spare digital inputs; Dual EGTS or multiple temp sensors inputs require Innovative SSI box
Water/Alcohol Injection Control
Integrated Diagnostic LED's for easy visual confirmation of proper Trigger, Fuel Injection, & Ignition System operation.
Instant Dual MAP Switching capability for street & track vehicles!
User Configurable Sensors - compatible with any and all senors like FFE trigger wheels, or GM AIT or ECT sensors
Serial Port connection for zero soldering wideband o2 sensor installation
Race Dash Integration via Serial Output.
Innovative Wideband/TC-4/SSI-4 Daisy Chain Compatible via serial connection.
PLX Multi Display Gauge & Android App Compatible for real-time engine parameter display.
If OEM harness is not available or in good condition; Adaptronic Wire In Models(E420D, E440D, E1280S) are available with either flying lead or terminated wiring harnesses.
20B 3 rotor swaps require E1280S Super Computer.
Easy to use WARI tuning software with USB connection to PC's running Windows XP, Vista, 7, & 8.
Easy Datalogging with no additional hardware/software.
Excellent direct and community technical support.
12 Month Warranty
http://www.youtube.com/watch?v=GANKqQBhDGY&list=UUorGju4Jqyl3dCXFIgqWpUQ&feature=c4-overview
12 Month Warranty
