da1nonly said:I seem to average about 9.5L/100KM...
cron said:I would be satisfied with that. Actually, I went from 14.something to exactly 13 in a month (always same driving). I'm going on a long ride next weekend, so I expect it will be much better when I'll come back.
If I can get about 10 with my driving (4 persons in the car, city driving), I'll be more than happy!
jandree22 said:358.7mi. / 12.188gal = 29.43 MPG. 75% City driving
Oh so close to the holy grail of 30MPG, but not quite... maybe this next tank (second)
Skylab, what do you do to get that kind of mileage on the trip odo? What type/speed of roads are you on? How many clicks to you go through when topping off? I'm intrigued as to how you're getting so freekin close to 500 mi on a tank! (wow)
Skylab said:Ok, it's like this(and yes, it will sound kind of corny):
1. You have to believe that good gas mileage is achievable. I'm very light on the gas pedal.
2. Don't ever go over 65mph on the freeway.
3. Use cruise control on the freeway most of the time. Drive in the slow lane. Leave on time, or early, so you won't be late...thereby eliminating the need to speed.
4. Coast whenever possible! I live in San Diego, and yes, there are plenty of hills/mountains here. My commute is about 20 miles each way...whenever there is a downhill, I put the car in neutral and coast...you'd be surprised how fast your car will coast downhill...easily at 65mph, sometimes faster! On the way to my job, at least 2 miles of that is coasting...that's collectively. Obviously, on the way home, I can't do that, because I'm going back uphill somewhat.
5. Having a manual transmission helps. I guess you could try this with an auto...your results may vary.
6. I top the tank off all the way to the very top, untill a little bit of fuel is visible right by where the cap screws on. My local gas station has pumps w/out the springs in the nozzle...so it's easy to top off. A fillup is usually 14.7 gallons. Yes, I run it close to being empty, but there are so many gas stations around here, there's no fear of running empty.
That about sums it up...
2006 Mazda 5 (16,600 miles) My Mazda 5's Average Fuel Economy: 30.8mpg's on 14.7 gallons of gas
oh, and here's the stats on the supposed MPG ratings for the Mazda 5:
EPA Fuel Economy:
Fuel Type: Regular Gasoline
MPG (city) 22
MPG (highway) 27
MPG (combined)24
Average User MPG
25.6
Disclaimer
Miles on a Tank: 343 miles (boom08)
http://www.fueleconomy.gov/feg/sbs.htm
Good luck!
i had my mazda 3 get a check engine light go off from overfilling (thank god it was under warantee)... if you overfill, there is a sensor in the gas tank that can be damaged... oh, and my 5 averages about 25 to 26 mpg (i can baby her and get it up to about 28)...
Wytchdctr said:thats a really good way to kill off the evap system.
its a hit and miss thing.... I got my car serviced in NJ, so I think they fix these things under warantee as a rule... (most of NJ is full serve at the gas pumps)Skylab said:I'm aware of this...this is the fourth car I've done this with, and perhaps I'm playing russian roulette, but there's never been a problem with any of the cars before. (125,000mi. on one of them)
How long will it take for something to go wrong?
WhiteStar III said:Best recorded mpg was near 32mpg, but I discount that as it was early into ownership, and I never had any true indication as to how much fuel the tank could take (until recently); but I have gotten above 30 with some regularity.
Skylab said:6. I top the tank off all the way to the very top, untill a little bit of fuel is visible right by where the cap screws on. My local gas station has pumps w/out the springs in the nozzle...so it's easy to top off. A fillup is usually 14.7 gallons. Yes, I run it close to being empty, but there are so many gas stations around here, there's no fear of running empty.
You'll get run over by other larger vehicles here.Skylab said:2. Don't ever go over 65mph on the freeway.
