- MazdaSpeed 6
ohh i plan to roll for sure.
i am pretty sure you will, H&R go pretty low right?
stock offset already puts us fairly close, going to 8" wide with lower sounds like a 100% chance to rub.
plan to fender roll/trim in your near future.
What's your offset? I'm on stock wheels (18x7.5) with 235/40/18 tires and springs, I'm dropped 2" if not more (the lowest of speed6s I've had my car next to).
I don't rub but if I went with 8" wide wheels I'd rub for sure (you can barely fit your fingers between tire and fender but you can still see the fender and the non-rolled area is probably like 1/4 of an inch from the sidewall of tire).
If your offset is +48 or less, even on 225 width, I'll guarantee you rub.
well im going to be 1.3-1.4 inches lower.. i bought the set of tires and rims from tire rack so im not to sure what the offset is on them.
yeah ive been looking into buying a fender roller from Eastwood.. figure im gonna need one in the future for the business might as well buy it now. 269 retail isnt bad, i bet i could get it alittle cheaper by calling them up and seeing if i could rep them as a sponser for their line of products.
why exactly would it look silly? Yes, the car looks better lowered a little, but it doesn't look bad without it lowered. There are other mods on the list ahead of new suspension bits.I'd say on stock suspension you'll probably be fine, but it will look silly without lowering the car...but judging from your avatar, i guess you aren't concerned with the car looking like a monster truck.
