Prostitutes don't suck oil where I'm from. Maybe you should get that checked out by a doctor...
Theres nothing saying its definitely the turbo. When I cooked a ring my engine did the exact same thing, hence why I said to look at the plugs first.
im a certified mazda tech.... i see plenty of mazdas blowing smoke all the time and 100% of the smoke comes from the turbo seals .
Engine Exhaust Emits White or Blue Smoke
Possible Causes
Remedies
Dirty air cleaner element
Inspect and replace air cleaner if necessary.
Restricted duct between air cleaner and turbocharger compressor
Remove restriction or replace damaged parts as necessary.
Seal leakage at the compressor end of turbocharger
Refer to this symptom troubleshooting chart for "Oil Seal Leakage at Compressor End of Turbocharger".
Seal leakage at turbine end of turbocharger
Refer to this symptom troubleshooting chart for "Oil Seal Leakage at Turbine End of Turbocharger".
straight from Mazda MS3 support system.
Excessive Engine Oil Consumption
Possible Causes
Remedies
Wrong type or viscosity of engine oil
Replace engine oil with specified viscosity and grade.
Seal leakage at compressor end of turbocharger (indicated by oil in housing or on wheel)
Seal leakage at turbine end of turbocharger (indicated by oil in housing or on wheel)
Oil in engine exhaust manifold (indicating malfunction of rings, pistons, valves, etc.)
Diagnose and correct as necessary.
