Or maybe you just like to make up imaginary explanations to explain things you don't understand.
Read up some more. Then get back to the discussion.
Here's a primer though.
When something is electronically controlled, how does changing the size of said item effect the response of the electrical equipment attached to it? This is an electronically driven throttlebody, and what works/changes/effects a cable based system, does NOT have the same effect on this one.
Removing restriction, and effecting response, are two entirely different aspects of performance. A dyno doesn't indicate that response was increased, because response is not interrelated with power production.
For added reading, look up how various diameter sizing is done on exhaust/intake inlets to effect the response/performance of the vehicle.
Here's some sites to start off at...
http://www.musclecarclub.com/main.shtml
http://autozine.kyul.net/technical_school/tech_index.htm
http://www.howstuffworks.com
And if you ever want to have a civilized conversation or debate, its best not to try and insult the people your talking to in your post (as I did at the begining at this one) it puts them immediately on the defensive, and prevents a rational conversation from occuring...asshat.
