can someone give me a little help with installing a SS clutch line..for example, what is involved with replenishing the cutch fluid? I think it shares the same fluid with the brakes??
Yup, clutch shares the brake fluid resevoir. Remove stock line, replace with SS line.
You will require an assistant for this next part:
At the end of the cluth line somewhere there is a bleeder screw (probably 10mm), have your assistant pump the clutch pedal while you open the bleeder screw, let some air out, then close the screw before the assistant releases the clutch pedal. Top up brake fluid. Repeat until no air, or brake fluid/bubbles come out of the bleeder screw.
It's important to make sure your assistant doesn't release the pedal while the bleeder screw is open, this can suck air into the line, which you don't want!
