I just received my spin on conversion kit for our Mazda5. Is there anything I need to know before installing it. I have some time before I put it in because i just did the oil change on it, and I plan on keeping the original setup until the next change. I am pretty excited about this, as I have really tired of dealing with the cartridge filter and the mess/extra time it takes to service over the last 3 years.
The total for the kit with shipping was $93.92. The kit comes with the gasket that goes between the filter housing and the block (part LF02-14-342), the spin-on filter (LF-05-302B), and the new sandwich style filter housing body (L311-14-311A w/ L311 S5209 on casting). Ours has the engine coolant unit that attatches to the top. I have read that sometimes this cooler can be problematic upon removal as the gasket in between it and the filter housing body tears or gets damaged. Is there anything I can do in particular that will prevent that from happening? Also, is there a torque spec for that upper coolant unit and the bolts to the engine block? I want to be very thorough so I don't end up sitting down waiting for more parts if something happens during the replacement. Just in case, what would the part number be for the gasket on top?
It has been said that a Motorcraft FL-400S filter fits this housing as well. It is a little deeper, having more capacity, and is a little more common in many places. I tested this theory tonight, as I have a used one sitting in the trash after just doing the oil change on my 2000 Ford Focus, and the threads are spot-on with the gasket sealing on exactly the same profile as the Mazda filter. Even the numbers (3, 4, and 16) stamped on the inside top of the filter are a match. Now I will only have to stock one filter between the two cars...BONUS! I am curious to see how much farther down it will hang.
So if anyone has a broken stock housing, stripped threads, or whatever, I have a good one. The plastic bottom is a little worn on the outside with some marks on it from previous removals but the threads in it are great. I always oiled the o-rings before installing them, and was careful removing the old o-rings to make sure not to nick the surfaces. The rest of the housing should be just fine once I remove it. Just pay the shipping and it's yours (as soon as i get it off).
