the stock pcv valves are inadequate for our cars from the factory. under boost there is a small amount of blow by that goes into the crankcase. but since our pcv's suck, they cant allow enough of the crankcase pressure through the valve and back into the intake manifold and in turn the pressure finds its way to the closest path to release the pressure which would be the vent line from the driver side of the valve cover to the pre-turbo intake system. eventually finding its way into the turbo, intercooler, and coldpipe finally being burnt off through the combustion cycle.
