Hello everybody back with another msp... sold the blue one but back to my ? im looking to upgrade the coil pack and wire set up on my car currently running ngks and ngk zfr6f v-power plugs.... Current mods are 2.5 divorced downpipe, perrin turbo back, atp sr20 8 psi wastegate, injen intake, samco pipe hot pipe, relocated maf, custom cold pipe, jdm 1st gen hks bov, and also running the stock bov to recirculate into the intake with vacuum a line split to both bovs coming from the brake booster no boost gauge.... so i would like to to upgrade the wires to get a better spark cuz i think im having some ping but don't want spend to 200 on nologys but will if i have to so ive looked in to these wires
1st Magnecor 8.5 kv85 model
Dont know much about them
2nd Nology hotwires
I had these on my blue msp with the same ngk v-power plugs the the metal grounds from the wires were connected to the 1sty ground kit and it took away hesitation and jerks and my car kept boost strong but its really expensive
3rd 1.8 conversion with ngk wires and the mounting bracket
im planning on buying this from a forums member and what i guess i know is that im gonna have to use the 1.8 or the 626 valve cover for it seal really good would i have to extend the wires running to coil that feed power and would i have to change the ends to fit the 1.8 coils and is it really an upgrade or worth doing
4th 2000 626 distributer and wire
I read somewhere that we can use the 2000 626 distributer and wire set up with mounting bracket but if so we have to power feeds for to the coil how would both be plugged in for to power to the plugs dont know much
So im looking for anybody with personal experience or that could steer me in the right direction a lot the info is scatter through all the other post so im trying making sure
2nd Nology hotwires
