- 2001 Pro 2.0 LX
try regreasing the shifter. you probably didn't use enough on the ball where it pivots.
lazymfg said:I have the B&M, but lately i have found it hard to shift into or out of gears? what would be my problem? but when its not acting up, its a great shifter. also what does the bushings do? thanks
Wes said:I just installed my TWM shifter and Kartboy bushings last weekend, the verdict...
I am not sure I like it honestly, the throws are super short (more so than the B&M I had in my Accord) but it's hard as hell sometimes to get it in gear. There isn't much benefit to a shorter throw if it's difficult to get into gear! I greased the ball joint really good, but it just feels like I have to force it way too often.
I am hoping that it will be a bit smoother when it warms up here, but I also read recently here that changing the tranny fluid can help a lot... might have to try that.
Laser03pro said:Wes my kartboy is the same way do you have the twm with the bearing? "2nd Gen"
they will loosen a LITTLE, its just physics, the lever is shorter and fulcrum is closer to the center, it will take more effort to shifter, but the shifting is crisper and quicker. if you go back to stock, it seriously feels like driving a bus.jjac28 said:i just had my b&m shifter installed. i have the same problem , its tight and its hard to shift...im hoping i just have to work it in and with time it will loosen up
just like you said there isnt much benefit if its hard to shift...
