Wagonbacker9
- 2004 'Hoe
so just don't try? um.... dude...no.
im confused, you had it relocated, then switched back to the intake side? because you are saying you wen from the pressur side to the vaccum, nd that the same thing.
If you thin the pressure side and the Vac side of the turbo are the same you need to look into what you are talking about.
lol your incompetence makes me laugh. there is an inlet, and if your refering to this inlet as a vacuum then you are wrong, yes it sucks in air but it is not a true vaccum. then there is the "pressure side" which you are refering to, this is where there is either vaccum or boost. these are the hot and cold pipe that people may refer to, or basically intercooler piping. the only time there is outward pressure is when the turbo produces boost, otherwise it is a vacuum i know what i am talking about, and thinking i dont is not helping me.
