I've owned the vehicle for about a month now. It has only happened maybe 3 times, but upon startup, the engine seems to be starving for gas and almost cuts out as it desperately tries to run. This is only for about 2-3 seconds. It isn't the high rpm running for about 30 seconds, I understand that part is normal. This is much different and I was wondering if anyone else has noticed this. Could it be a problem with the fuel injection? It hasn't been a problem, but I want to make sure it isn't destroying anything. I struggle to describe it well, but it seems to struggle badly upon startup, then after a few seconds it's fine. Any help is appreciated.
