CheeseHelmet
It'll be soft until a certain point; the pedal shouldn't hit the floor. If it does, you have a problem.
trust me, there is air in your lines. pay the $50 or whatever and have a shop bleed them out.
when i pump the pedal and build up pressure with the car off, it stays firm
Is there a large mushy section before it becomes firm?
Also, are you sure it's firm and you're not just hitting the floor?
Of course they're compatible, that's not your problem. Either you still have a s*** load of air in your lines or the master cylinder is bad.
have you tried to gravity bleed the system?
Also, you say you "almost" put a litre of fluid through the system, I usually go through 2 bottles when flushing the system; maybe I'm an over achiever?
Did you not get to try my gravity bleed? That's what I was getting at when suggesting that method.
