Green2000~ES
- 2000 Mazda Protege ES
so I thought I'd try here....
Replacing Blown Engine ~ Should I modify the replacement?
I have a 2000 ES 1.8L auto, the engine isn't really blown, just f'd up a piston when it sucked up water through the CAI Don't ask!!! anyways, the car has 90k miles on it and I found 3 2000 1.8L engines for good prices with under 40k on them. Was thinking of just running a few checks flushing the oil system and the cooling system, making sure everything seems ok, then dropping it in the car. (2 of the places will let me see it run before I purchase) also I found 2 decent 2.0Ls
so my questions are:
are there any worth while machine shop mods to make? porting? polishing? valve job?
any good cams?
timing gears?
any other ideas?
thanks guys.
Yesterday, 11:34 PM #2
Green2000~ES
Registered User
Green2000~ES is Online:
Posts: 2 Another thing... I need the passenger side upper motor mount, and I'm sure others. whats the best motor mount to replace it with? there seems to be a few opions on here.... I'm thinking of replacing all of them at once..
also wanting to add a header and maybe an exhaust system.. any sugestions?
any good cams?
timing gears?
any other ideas?
thanks guys.
Green2000~ES
Registered User
