So last night while driving home I noticed that the lighting output was off and dim, it did not have a crisp cut off line line it normally did. It looked like the aim was way low asked my wife if she had noticed it before and she said she did also. So when I got home and had the lights on shining on the garage door It looked like the drivers side was way low and made the output look weird, almost like a big shadow was ware the cut off line suppose to be. also the headlight adjusters did not work.
Well after a little investigation It turned out that one of the bulbs on the hatch on the passenger side was out. After putting in a new 194 bulb and turning on the headlights everything was back to normal. now I need to change out the rear plate bulbs now because one of them are burned out. Not sure if any one had this happen to them yet but hope this helps down the road.
