P Phatmatt Member : Mazdaspeed Protege 2003 May 25, 2015 #1 When I connect a scanner to my car (tried 3) I get no power. My scanner never powers on. Is there a fuse for this? I checked and didn't find one. I need to pull some codes. Thank you.
H hornsfan10609 Certified Mazda Tech : 2003.5 Mazdaspeed Protege x2 May 25, 2015 #2 There is a fuse don't recall which though, should be easy to see which one is blown.
P Phatmatt Member : Mazdaspeed Protege 2003 May 27, 2015 #4 Checked all fuses with a test light, all checked good.
H hornsfan10609 Certified Mazda Tech : 2003.5 Mazdaspeed Protege x2 May 28, 2015 #5 Then it could be a lot of things, damaged wire, damaged connector, failed ECU, low battery voltage, fuse not seated correctly, etc
