Ferdball said:AP stands for AccessPORT.
http://www.cobbforums.com/forums/showthread.php?t=32887&page=4
Thank you very much!
BlackJack said:The Xede EMS does just that. Not only reprogramming the ECU, but also increasing the HP/TQ by a HUGE amount, from 225RHP to 280RHP.
took me 20 minutes to install my XEDE...MS6S2K said:I just briefly searched some info it. This is not plug and play like Subaru has. That will be far better and more reliable then this it ever comes out. This looks like a major project to install, and a bad risk. Cobb is simply plug in, install, load up, and go. Takes 20 minutes, and anyone with half a brain can install and use it. Not one hint of a problem, perfect tuning. I guess I'll just have to hope Cobb makes one. And 225whp to 280whp with nothing more then ecu programming? I don't buy that. There's gotta be intake and exhaust mods needed. I would have been close to 300whp in my STI if I had simply added the COBB intake and exhaust mod to my Cobb tuner.
Well that sucks for you that u cant believe it, it does what it says and there are numerous post on here showing just that, there is a guy in a MS6 that just ran a 13.1 at 104 with just the XEDE and he only cut a 1.8, so you might want to read a little more before you bash itAnd 225whp to 280whp with nothing more then ecu programming? I don't buy that. There's gotta be intake and exhaust mods needed. I would have been close to 300whp in my STI if I had simply added the COBB intake and exhaust mod to my Cobb tuner.
$inCitySpeed3 said:Well that sucks for you that u cant believe it, it does what it says and there are numerous post on here showing just that, there is a guy in a MS6 that just ran a 13.1 at 104 with just the XEDE and he only cut a 1.8, so you might want to read a little more before you bash it
no, you obviously DONT know how to read. He ran a 13.8 with the intake and exhaust. Then with the XEDE ran a 13.1. If you dont think that .7 seconds off a 1/4 mile time isnt impressive, especially at that level.. you are a moron.MS6S2K said:I have read enough. The guy that ran that 13.18, has intake and exhaust mods, NOT just the Xede as you claim. I'm talking about taking a bone stock Speed 6, 20 minute install, and 280whp, like the car came that way out of the showroom. No CAI, no exhaust upgrade, just the Xede, and nothing else. Naturally with any additional mods of course I believe it. I believe it, but I don't believe with the stock exhaust and intake, you can add 50+whp just by adding a Xede, not on my Speed 6 and not safely. That exhaust is too restrictive. I'm weery of the long term reliability with the Xede. I don't doubt it's potential. Gotta be plug and play for me. That's why I'll hope and wait for Cobb.
Nutari said:no, you obviously DONT know how to read. He ran a 13.8 with the intake and exhaust. Then with the XEDE ran a 13.1. If you dont think that .7 seconds off a 1/4 mile time isnt impressive, especially at that level.. you are a ******* moron.
(gtfo)
MS6S2K said:^^^^^^ I don't doubt the Xede one bit in it's capabilities. However, I go by what Cobb and other leading ECU tuners do tuning cars. Example: I had a stage 2 map for my STI. However, I could not run that map safely until I modiifed the intake and Exhaust. Cobb warns you not to dare use those maps until you add intake and exhaust. So sticking with the Stage 1 map (mild tune) was required, you only gain about 15-20whp safely. I did play around once, and I plugged in the Stage 2 map briefly, and I tell ya, the STI was ready to tear like a mofo. However, it was dangerous to use that kind of tune without modifying the intake and exhaust first. Once you do that on an STI, you can use the Stage 2 maps, and gain an additional 40+whp, on top of the 20whp what just using the Cobb AP gives you if you don't modify anything else. If all you do is modify the intake and exhaust, and don't add the Cobb AP tuner, you will get minimal gains just as you would with the CAI and exhaust mod on the Speed 6.
This is what has me confused. I also realize that Cobb puts safety and reliability as a top priority, but I was always told by many that ECU tuning is really not much of anything without intake and exhaust mods, and vice versa.
I'm curious as to how the Xede avoids that requirement, and how you can push the gains so large and safely, without adding the intake and exhaust mod. I'm not doubting it, I'd just like to understand it better. What makes the Xede safe at high levels of ECU tuning on a Speed 6 with such large gains modifying nothing else, and not on the Cobb or other ECU tuners? I'd like to see some dyno results and track times with just the Xede, and no other mods at all. Hopefully over time we'll get to see that. Perhaps I am underestimating the potential of this Speed 6, by just modifying the ECU. It doesn't seem believable that you can add 40-50whp safely and effictivley without doing anything else, like intake and exhaust. Thanks for reading, and I hope someone can answer my curiosity, as I'm awaiting that day when I can modify my Speed 6 safely and effectvely!!
MS6S2K said:^^^^^ Thanks for the great info. I guess what took me is the responses to the 13.18 1/4 mile time as "install the xede and shave 6-7/10ths of the Speed 6 bone stock 1/4 mile time." When I challenged it, people argued it. That just isn't accurate IMO. I will just have to keep my opinion that you cannot get 40-50whp safely and efficiently from just running the Xede with no other mods. If that ends up being false, then I'll be the first to admit I am wrong. I also believe that the Speed 6 will respond similiarly to the STI and other cars regarding mods. Once you open up that intake and exhaust, and allow that turbo to breath, you can really get some high boost efficiency, car will run much better, and it will make the ecu mod like the Xede shine, and bring the car to a whole new level, which I believe the person who ran that 13.18 did. They also really know how to drive to pull off that time, and didn't mind truly hard launching their car, so I'm actually more impressed with the driver then I am the mods.
If I start to see dyno runs of 270+whp and 1/4 mile times in the 13.3.13.4 range just by installing this Xede and nothing else, and with no potential problems, then I'll not only be happy, I'll willingly stick my foot in my mouth. Thanks again for the great write ups.
Captain KRM P5 said:i'd be happy to put the stock air box on the car and see where it runs with it versus the CP-E intake. i think it would easily hit 13.4 without it and validate the claim that you can shave 6/10ths off stock with the system. if it didn't then i'd be the one putting the foot in my mouth
that said, i'd honestly stake my reputation on the car hitting low 13s even with the stock air box on. its due to rain all weekend here, but if weather clears up enough to where we can get some passes in, i'll see if we can do it.
i dont think that is the case, he only pulled a 1.8 in a AWD or 4WD, which i think there is great room for improvement, not saying he cant drive, but i will bet he could beat it a little harder off the line...also about your dyno post, a DYNO is a tuning tool, it just happens to read HP and TQThey also really know how to drive to pull off that time, and didn't mind truly hard launching their car, so I'm actually more impressed with the driver then I am the mods.
$inCitySpeed3 said:i dont think that is the case, he only pulled a 1.8 in a AWD or 4WD, which i think there is great room for improvement, not saying he cant drive, but i will bet he could beat it a little harder off the line
MS6S2K said:I'm not doubting the capabilities of the Speed 3 and 6. What I'm doubting is the claim that by simply installing the Xede (no other mods) you can add 40-50whp safely, which then would result in shaving 6-7 10ths off the 1/4 mile time. So far no one really is arguing against me, or able to truly prove that claim. Of course once you add intake and exhaust mods, I believe it, and I also believe it's capable of even more. I just want to get to the bottom of this. I'm the type of guy that does not want to modify my intake and exhaust. I like the quiet ride. I'm looking to add some more power with some plug and play. I just want to know what the true gain is, because I can't get myself to believe I will be able to add 40-50whp just by buying and installing this. But believe me, I'd love to be wrong. Just waiting for evidence of this claim.
dread said:and there is no proof that the accessport can be traced. .
MS6S2K said:Well, if you really want to accurately measure the gains, you need to have a bone stock Speed 6, then run a baseline dyno, and than a Xede dyno. There's really no accuracy when running at the track to create your own dyno results by comparing 1/4 mile times. Shaving 6/10ths of a second can be done simply by one mediocre launch bone stock, followed by a great launch with the Xede. Also weather conditions, ect ect play a role, so it makes it even less accurate. Also keep in mind, people have run 13.8 bone stock, so you should base that gain off of the best achievable time gotten on a bone stock Speed 6, not a magazine time or personal time.
I notice how you are talking about 1/4 times, and not dyno numbers. Do you believe the Xede system alone safely adds 40-50whp to a bone stock Speed 6 with no other mods.
