Antoine
Administrator
Congratulations to Concept MSP (first)
Click below to VOTE for the next MOTM!
OPEN TO ALL MAZDAS!
*Mazda of the Month 2.0* VOTE now for March!
OPEN TO ALL MAZDAS!
Chris
2003 Mazdaspeed Protege
Exterior Modifications:
Custom Painted Fiber Images Carbon Fiber Hood (A1 Auto Body)<O</O
Xcelerated Concepts Carbon Fiber Trunk<O</O
Gloss Black Custom Painted Roof (A1 Auto Body)<O</O
Black Painted Trunk Latch Cover with Shaved Keyhole (A1 Auto Body)<O</O
Center of Rear Lip Painted Black (A1 Auto Body)<O</O
Custom Painted DG Motorsports Urethane Front Lip (A1 Auto Body)<O</O
Custom Painted DG Motorsports Carbon Fiber Eyelids (A1 Auto Body)<O</O
DG Motorsports Carbon Fiber Mirror Covers<O</O
DG Motorsports Carbon Fiber Upper Grill<O</O
Professionally Tinted Windows (Kartunes)<O</O
Bluebatmobile Red Tail Light Overlays<O</O
Bluebatmobile Smoked Foglight Overlays<O</O
Amber Side Markers<O</O
CATZ Galaxy White H4 Headlight Bulbs<O</O
CATZ Galaxy White H3 Foglight Bulbs<O</O
Varad Multi-Color LED Undercar Lighting System<O</O
<O</O
Wheels & Brakes:<O</O
Gloss Black Custom Painted 18"x7.5" Rays Engineering G-Games Wheels (A1 Auto Body)<O</O
215/40/ZR18 Dunlop SP Sport FM901 Tires<O</O
Rotora Front Big Brake Kit (13" Cross Drilled & Slotted Vented 2 Piece Rotors, Cast Aluminum 4 Piston 2 Piece Calipers (Metallic Blue), Black Anodized Caliper Mounting Brackets, Rotora H2 Ceramic Competition Pads, Stainless Steel Braided Brake Lines)<O</O
Rear Centric Slotted & Cross Drilled Rotors<O</O
Rear Akebono Pro ACT Brake Pads<O</O
Rear Russell Stainless Steel Brake Lines<O</O
Wilwood High Temp 570 Brake Fluid<O</O
Speed Bleeders<O</O
Black Gorilla Lug Nuts<O</O
<O</O
Suspension Modifications:<O</O
Eibach 1" Pro-Kit Lowering Springs<O</O
GTSpec Front Lower Tie Brace<O</O
GTSpec Front Strut Bar<O</O
GTSpec 4 Point Ladder Bar<O</O
GTSpec Rear Lateral Arm Braces<O</O
GTSpec Rear Strut Bar<O</O
<O</O
Interior Modifications:<O</O
3 Auto Meter 2 1/16 Inch Angle Rings<O</O
Custom Molded 3 Gauge Pod with Molded Radio Trim Ring<O</O
Auo Meter Carbon Fiber Gauge Cup<O</O
Auto Meter Ultra-Lite 2 1/16 Inch Electrical Air Fuel Ratio Gauge<O</O
Auto Meter Ultra-Lite 2 1/16 Inch Mechanical Boost Gauge<O</O
Auto Meter Ultra-Lite 2 1/16 Inch Electrical Oil Pressure Gauge<O</O
Auto Meter Ultra-Lite 2 1/16 Inch Electrical Oil Temperature Gauge<O</O
Auto Meter RPM Activated Module<O</O
Black Auto Meter Quick-Lite Shift Light<O</O
Carbon Fiber Gauge Overlay<O</O
Dave B Brushed Aluminum Gauge Rings<O</O
DG Motorsports Carbon Fiber Gauge Bezel<O</O
DG Motorsports Carbon Fiber Glove Box Cover<O</O
DG Motorsports Carbon Fiber Shift Plate Cover<O</O
DG Motorsports Carbon Fiber Armrest Cover<O</O
Black Leather Shift Boot with Orange Stitching<O</O
Black Leather Ebrake Boot with Orange Stitching<O</O
Kartboy Black Anodized Aluminum Shift Knob<O</O
Sparco Drilled Aluminum Racing Pedals With Rubber Inserts<O</O
P7 Aluminum Dead Pedal<O</O
Light Grey Microfiber Suede A Pillars with Molded Tweeters<O</O
Light Grey Microfiber Suede B & C Pillars<O</O
Light Grey Microfiber Suede Headliner<O</O
ScanGauge II
<O</O
Speed Bleeders<O</O
<O</O
<O</O
ScanGauge II
Performance Modifications:<O</O
Ceramic Coated Thunder Stainless Steel Tubular Exhaust Manifold<O</O
Unichip Piggyback ECU<O</O
A'PEXi Turbo Timer<O</O
Injen Cold Air Intake<O</O
Magnecor Spark Plug Wires<O</O
MAZDASPEED Oil Filler Cap<O</O
MAZDASPEED Radiator Cap<O</O
Optima Red Top Battery<O</O
Custom 4 Gauge Ground Wire Upgrade<O</O
GReddy Coolant Catch Can<O</O
Kartboy Short Shifter<O</O
Kartboy Shifter Bushings<O</O
Apex Motorsports 2.5" Downpipe<O</O
Extreme Parts Custom 2.5" Exhaust with Vibrant Muffler<O</O
Kartboy Exhaust Hangers<O</O
AWR Front and Rear Motor Mounts<O</O
Polished Heat Shield<O</O
Gloss Black Painted Valve Cover<O</O
DG Motorsports Carbon Fiber Engine Cover<O</O
Black Mazdaspeed Reservoir Covers<O</O
Perrin Performance Front Mount Intercooler<O</O
TurboXS H-34 Racing Bypass Valve<O</O
Chromed Engine Brackets and Battery Tie Down<O</O
Black Silicone Couplers<O</O
Vibrant T-Bolt Clamps<O</O
Hella 118db 500Mhz Supertone Horn<O</O
Custom Hood Dampers<O</O
Corksport Stainless Steel Clutch Line<O</O
Aluminum Oil Filter Sandwich Plate<O</O
Remote Mounted Oil Pressure Sender with Stainless Line<O</O
Corksport Aluminum Radiator<O</O
2 12" Slim Line Fans<O</O
P5 Upper Radiator Brakets<O</O
Aeroquip Starlite Radiator Hose<O</O
<O</O
Audio Modifications:<O</O
Alpine CDA-9856 Head Unit<O</O
Alpine SPR-17LS 6 1/2" Front Component Speakers<O</O
Kenwood 6" 2 Way Rear Door Speakers<O</O
Apline MRP-M350 Amplifier<O</O
Alpine MRP-T220 Amplifier<O</O
Phoenix Gold Xenon X12D4 12" Subwoofer<O</O
Custom Fiberglass Enclosure and Amp Tray Wrapped in Black Microfiber Suede<O</O
Dynamat Sound Dampening Material<O</O
Blaupunkt DVD-ME2 Mobile DVD Player<O</O
2 5.6" Screens in Headrests<O</O
Rockford Fosgate Type RF 4 Gauge Power Kit with Inline Fuse<O</O
Tsunami 4 GA 4 Input Positive Battery Terminal<O</O
Tsunami 4 GA 3 Input Negative Battery Terminal<O</O
Rockgord Fosgate Type RF Dual Twist RCA Signal Cable<O</O
2 Rockgord Fosgate Punch Performance Series Twister RCA SignalCables<O</O
Rockford Fosgate Punch Performance Series Fused Power Distribution Block<O</O
Rockford Fosgate Punch Performance Series Ground Distribution Block<O</O
Monster Digital 1 Farad Capacitor<O</O
Stinger Right Angle RCA Adapters<O</O
2 Varad 13" Orange LED Hyper Light Bars
<O</O
<!-- / message --><!-- sig -->
