Hey all,
Just had the ATF in one of our 2's flushed by the dealer. The car's at 30k, and knowing how Mazda automatic transmissions tend to be hard on fluid, it was due. The owner's manual specifies that Mazda ATF M-V (Type M5) fluid should be used, and some research on my part has taught me that it's a similar, but not identical, fluid to Mercon V.
After getting the flush done and looking at the paperwork when I got home, lo and behold it looks like the dealer used Mercon V fluid instead of M-V. They list part number 0000-77-120E-05, which has a description of "MERCON V ATF". But, right below it, is another line item for part number VP094 with description "TRANS 2-PART". I have no idea what this other item is, and can't find any info on it anywhere. I suspect it may be some sort of fluid additive (maybe to bring it to M-V fluid specs?) but have no way to be sure.
Anyone have any ideas?
