CHASSIS/BODY
Type: unit construction with 4 rubber-isolated dwarf-like subframes made by Home Depot
Body material: welded steel stampings and fiberglass-reinforced papier-mch
lol
INTERIOR
SAE volume, front seat: 53 cu ft
cargo: 80 cu ft
Front-seat adjustments: fore-and-aft, seatback angle, front height, rear height
Restraint systems, front: manual 3-point belts, driver and passenger front and curtain airbags, plus curtains
wtf, huuuuuge front seat
ENGINE
Type: Miller-cycle V-6, aluminum block and heads
Bore x stroke: 3.50 x 3.13 in, 88.9 x 79.5mm
Displacement: 181 cu in, 2961cc
Compression ratio: 10.0:1
Effective Miller-cycle compression ratio: 8.0:1
Fuel-delivery system: port injection
Valve gear: chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters
Power (SAE net): 245 bhp @ 6600 rpm
Torque (SAE net): less than 245 lb-ft @ 2800 rpm
<------lol
Redline: 7000 rpm
lol @ miller cycle, AFAIK the only recent production car to have a miller cycle engine was the millenia and I think miller cycles use a supercharger
Vehicle type: front-engine, 4-wheel-drive, 3-passenger, 4-door wagon
huh?
