looks good..
DIY FTW...
I just use a jack and some jack stands...
placing the jack and jack stand on ms3 is a b****....all my work begins with positioning the two and it takes long as hell to position them. I have to buy that ramp. I was gonna do my oil today but friggin hydraulic jack sunk on hot asphalt. so pissed
I got mine at Kragen's.wtf. that website is retarded. how do i buy them???
The washer is not meant to be re-used. It is an annealed aluminum non-heat-treated washer. The idea here is that it deforms to match any irregularity as you crank down on the drain plug, thus sealing. This deformation is called "cold working" and it creates a finer grain structure in the metal which effectively hardens it. The problem then with re-using the washer is that it is not as soft the second time around and it may not seal as well. For $1, it is pretty cheap to just use a new one each time. Copper sealing rings are the same in that they get cold-worked and harder when you use them.The washer is simply a flat, aluminum washer. You should be able to reuse it multiple times unless you damage it somehow.
No, this is not correct. Both versions of Rhino Ramps have a 17 degree incline and are the same total height. The only difference between the two versions is the width of the heavy duty version and also the top platform of the heavy duty version is slightly longer to accomodate larger diameter tires more comfortably.Mine is also an '08.
The angle of the ramp is also different, which is why it won't go up the heavier duty version (steeper angle on that one).
any reason we couldn't find a part number for a drain plug with rubber gasket that would fit our application?
Maybe im just missing something but do u really need the supposed engine cover on the bottom with all those clips and bolts. Other then to help aerodynamics under the car is it really neccessary?
I bought a magnetic tip drain plug with plastic gasket...
Don't know, I just put it in... I know on my other vehicles, it catched quite a bit. I'll let you know next month or so...how much does the magnet catch?
By the way, i've been looking through this thread and don't see the official torque spec for the oil pan drain bolt mentioned. What is it?
For lots of reasons . I agree it is a pain though.Maybe im just missing something but do u really need the supposed engine cover on the bottom with all those clips and bolts. Other then to help aerodynamics under the car is it really neccessary?
