After searching 13+ pages of threads with no answer I decided to start my own thread.
A little history:
Last week: Car was stalling, had to keep revs above 2500rpm to prevent. CEL on/off periodically--FIX: EGR valve replaced. Car drives fine (In retrospect I should have tried cleaning it before having it replaced.)
Later that week: CEL--Idle adjuster out of whack due to above--FIX: reset ECU (damn Mazda techs)--Car drives fine.
Last night: CEL--Mazda tech says I'm throwing an O2 sensor code. They want to replace the sensor for $300+. I told them to wait. The car is driving fine.
A little more history
OBX header installed approx 10k miles ago. Spark plug fouler method used to prevent CEL. Drilled one fouler to 1/2", connected to sensor, connected to other fouler, then connected to header. Install went flawlessly and car performed well.
Finally the questions:
Anyone else had/having this issue? Does the fouler need to periodically be cleaned? Any other ideas? How do I reset the CEL should I attempt a cleaning?
In closing:
Looking forward to hearing everyones thoughts. I plan on picking up the car tomorrow so let me know what you're thinking ASAP. If I have to replace the damn sensor I can do that myself.
~Matt
A little history:
In closing:
~Matt
