- 2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
well from your standpoint and having been in and out of these motors quite a few times....what would be an amount of miles of lets say semi harsh driving to start looking out for in such a situation? i know its a general question but would a high MS3 motor be considered 60-70-100 thousand miles? and if you say the damage is done and the vehicle cant just lower its boost or return to stock and poof....damage is gone....how should we be monitoring these types of things? obvioulsy gauges and scan tools but i mean...could this have been avoided like going to get a check up for clogged arteries b 4 the heart attack? or is it quite impossible to really make a judgement unless them otor is torn down? thanks.
rule of thumb is real simple. the only warranty safe mod is not to mod. the less you mod, the safer you are. its really not rocket science beyond that. engineers with much bigger paychecks, much higher education, much more experience put these cars together after years of R&D. even then when the cars hit the roads there are recalls and TSBs and bulletins. if you think any company or individual is going to out-engineer that level of expertise on a part to part basis and expect the same longevity, you're wrong. i don't care if you're Dominic Turetto or CPe, its not going to happen.
its like when they tell you in high school "abstinence is the only 100% effective method". like it or not, its true. and like it or not, we're all still going to play with fire
the trick is knowing your limits. the problem is we tend to get the bug and need more and more speed. which is fine, for the most part, if you know what you're doing or paying someone who does. but you gotta pay to play, which means accepting the possibility that something can and will go wrong and being ready to accept that.
i think the time has passed too where the die hard fan boys who believe the stock engines are superforgedwunderkinds has passed, thankfully. i'm not saying they are junk, but they're not built to the same level as other cars. GM and Mopar have factory power adding parts through the dealership for the Cobalts and Calibers. Mazda is skittish on releasing a cold air intake. it speaks alot about confidence in the platform and alot about purpose driven engineering when you look at how manufacturers approach the aftermarket like that.
I'm the world's biggest Mazda fan, but I've seen enough to know with a healthy dose of skepticism and reality what their cars will handle before going over the brink.
