- 92 & 16 Meyatas
300 could be many other issues as well....the code is stored for around 80 miles
I don't believe that P0301 is related to EGR valve failure. I know you said that coil was replaced, and wires, etc. However, i would check / replace the wire/boot for Cyl 1, and check the spark plug. BTW, did you replace the right coil ? It also could be Fuel Injector failure. Use some FI cleaner.
If you want to replace EGR and keep your car for a year or two, then go with US version, because it is easier to install.
Well, correct me if i'm wrong, but it's the Right Coil that is connected to Cyl 1 Spark Plug.
Replace your Right Coil also, and replace the Wire/Boot which is going from Right Coil to Cyl 1 (longest wire going from Right Coil to First Cyl on far Left).
That should take care of your cylinder 1 misfires.
that doesn't make sense, although you could be right. if the cylinders are numbered 1 through 4 and 1 is on the passengers side, the coil sits on the cylinder 1. We may just be confusing each other. When i said "left side" i meant while looking at the engine facing the windshield. Which is why I should apologize and remember that you should always refer to a cars sides as passenger and driver's side.
i suppose why i believe it's the egr is because it got worse when i tried to clean it, so i'm assuming i did a poor job cleaning/lubing.
The coil on drivers side does NOT sit on Cyl #1. It sits on Cyl #4, however it is also connected to Cyl #1 by the longest wire.
If you replaced the Passengers side coil with one short wire, then it is not going to solve your problem with Cyl #1 misfire. It will, however, make a difference for Cyl #2 & Cyl #3 because Passengers side Coil sits on Cyl #2 and it's connected to Cyl #3.
Cyl 1&4 fire at the same time ignited by Drivers side Coil (new term ? DSC ?LOL), and Cyl 2&3 fire at the same time from PSC
Stop screwing with your EGR and get a new one if you plan on keeping your car for two more years.
replaced the wires and driver side coil. no help. oh well. if anything they were old and it might help my fuel efficiency. going egr next.
no code reader, just go to autozone and thats the code they give me. no cel this time yet, but if past history repeats itself it'll show up soon. when i stop at a light it shakes and chugs and the revs bounce violently.
it seems to only happen once i disconnect the battery and reset the pcm. (like when i cleaned the egr valve). the first few times it actually stalls. then the cel comes on at some point and the stuttering at the stop light is there, but not as bad.
i read this thread and want to check it. not sure if it's the same motor? due to the pcm issue...
http://www.mazdaforum.com/forum/mazda-tribute-22/misfire-cyl-1-solved-27215/
