I started it and let it run for a bit, then started it again and let it get to operating temp, then dumped the engine flush in it and let it run for about 15 minutes then changed the oil and filter. Filled up the oil and put in some engine honey and let it run for a bit. annndd drum roll... still smoking. I'm not surprised and it may take a while for everything to do any good. I'll try to let it run for a while every day or so. I'm gonna see if I can upload my data logs here. Once it was warmed up it was idle at 700-750 rpm which I'm happy with. I also pulled the plugs and had the same findings 1 oil puddle 2 wet 3 oil puddle 4 wet
At one of the startups it wasn't smoking at all but then it began to again. It will calm down while idling but the second you give it any gas it puffs out a lot of smoke.
