Board CST time is off
mdaj
car
I noticed that since the board moved the cst time is off. Basically when selecting the time to be GMT -6 it will show eastern time stamp of GMT -5.
[enry@xeon2 enry]$ sudo /usr/sbin/ntpdate time.nrc.ca
24 Jun 17:08:22 ntpdate[29688]: step time server 132.246.168.148 offset 5.790672 sec
[enry@xeon2 enry]$
Looks OK to me?
things might run better if you removed this :D :
If you put the right thing in your user CP (right time zone and right DST setting) you WILL see the correct time.
[enry@xeon2 enry]$
Looks OK to me?
Enry...I think I found the problem...
Im on a mac (stooges) . When at work on the windoze machine it shows the correct time. At home on the pimpdaddy mac its off an hour. I will play around with it but thanks for your help (headbang)
Works for me(the 2 minute dif is because I ****** around for a second after loading the page)
