Big brakes on Mazda CX-5?
Possible? Anything is possible. Is there a pre-assembled kit? Probably not.
You would need a custom mounting bracket unless they happen to he the same fitment (unlikely). There are multiple BBKs for the CX5 out there
CYKA being one. You can get true bbk, front and rear with floating caliper if desired.
You'd have a better chance of swapping the CX5 Turbo's bigger front brakes. But instead I'd be looking at performance rotors (slotted and/or drilled, vented) and pads before going nuts transplanting calipers.
usually indicate warped rotors
bigger brakes are rarely needed on modern cars - there are 2 issues involved: heat capacity & brake torque
if you can lock the wheels and skid the tires then you have plenty of brake torque
if you race your cx5 you MAY need more heat capacity; rarely this can be an issue lon very long mtn. passes (descent) - for either the first thing to do is to duct in air to the F. rotors; often an owner has not replaced the brake fluid every 2 years (or every race) or has used an inferior product
anyway, use a dial indicator to measure run out on your rotors
You can also find stainless steel braided brake lines. Those will give much stiffer pedal.
If your brake pedal is vibrating when you step on the brakes, you need to either resurface the rotors or buy new ones. You can get a set of rotors for 100 bucks or so. :) A custom big brake kit will cost just about 10times that.
These guys have treated me great over the years.
It’s been well over a year, I would be willing to bet that the OP has it figured out by now.
Over a year and no one linked a set of rotors to the guy. Or made it clear that when your brake pedal vibrates it's warped rotors.
A least this thread is worth reading in a search now.
He hasn’t been back to the forum to check in over a year, so.....why bother?
Read my 1st reply. To make the thread searchable. One less thread full of people posting but adding no real input...Like you just did again.
Latest posts
