CX9 SportOwner
Neet Neet
According to Page 09-18-28 of 2007 Workshop Manual the Auto Light Illumination Level setting procedure is the following:
Auto Light Illumination Level Setting
CAUTION:
If any of the following occurs, the sensitivity cannot be set properly. Therefore, resume from Step 1.
►Each procedure and operation interval exceeds 5s
►Procedures are performed incorrectly.
NOTE:
Perform the procedure in a condition that allows verification of the headlight illumination because it is necessary to verify the setting condition according to the number of times headlights turn on.
1.)Turn the ignition switch to the ON position with the light switch in the OFF position and pulled back (Flash-to-pass ON)
2.)Switch the light switch from the OFF to the TNS position five times and return it to the OFF position
3.)Pull the light switch back once (Flash-to-pass ON)
4.)Turn the light switch to the TNS position
5.)Switch the light switch from the TNS to ON position five times and return it to the TNS position
6.)Turn the light switch to the ON position
7.)Switch the light switch from the ON to AUTO position five times and return it to the ON position
8.)Turn the light switch to the TNS position
NOTE:
►Switches to the sensitivity setting mode when the above operations are performed
►The headlights turn on for the number of times according to the current setting conditionsi. Illumination (Two times): Standard Sensitivity
ii. Illumination (Three Times): Low sensitivity9.)Switch the sensitivity by pulling the light switch back (Flash-to-pass ON)
10.)Verify the number of times the headlights turn on and that the sensitivity is set properly.i. Illumination (Two times): Standard Sensitivity
