See, the hydrolock discussions on here are always hilarious to me, but I tend to stay out of them, but it's gone on long enough.
It's horribly off topic, and I might start a thread about it somewhere else (although that is just inviting trouble), but briefly: to hydrolock your motor you need to almost flood it. Which requires that you either fully saturate your air filter or some part of your intake system so that water can get through it in the first place and then keep driving with it either fully or partially submerged to suck a lot of water into the cylinder, or just fully submerge the engine (and long before that happens lots of other things will go wrong and shut down the motor).
People seem to think that you get some water into the cylinder and boom, hydrolock. That's crap. Small amounts of water get into the cylinder all the time, either through humid air condensing because of pressure changes or temperature changes through the intake system or just simple road and puddle splatter. You get some water droplets in the cylinder and they just cook off in the heat and you get some hot and cold spots in the combustion chamber that lead to inclomplete combustion or maybe very mild pinging. Who cares?
Water doesn't (really) compress. That's why you use it in hydrolics, after all. To hydrolock a motor you need to get enough water into the cylinder that on the compression or exhaust stroke, there is too great a volume of water in the cylinder for the stroke to finish at which point you start bending things like crankshafts or piston rods since the water won't compress or move any further. You need to have more water in your cylinder than the volume of your combustion chamber. 2.0L motor, 4 cylinders each is 500cc per cylinder. 10 to 1 compression ration means the combustion chamber is 50cc in size. You need to get more than a shotglass of water into your cylinder to hydrolock a motor for this example. Our motor has a bigger combustion chamber and slightly larger cylinders, so it's even more water. This may not sound like much but considering the presence of a filter and how hard it is to suck water droplets and road splatter through it, saturated or otherwise, it's massive. You need to have your air filter submerged and saturated, and a CAI is about what, 12 - 18 inches off the ground? That's higher than your doorsill. You need to get yourself into deep freakin' water to hydrolock.
