DSMConvert
AWD...say Bye Bye
- Titanium MS6
hehe ok yes you are running VERY VERY rich....it seems like you never actually uploaded the newer map. To correctly upload a map to the afc you need to open the file you wish to upload. For example if you downloaded a map named 440lcruz, you'll need to first open the r4 sofware go to the file dropdown, select open and then find/select the 440lcruz file. ONce you have done this click connect to ecu and goto the drop down menu at the top and select map a. Now at the top left corner of the "excel" sheet will be 2 buttons, one to download the current map and one to upload the new map to the ecu...you want to write map to ecu...this will take a few minutes depending on the speed of your connection. ONce this is done then click the disconnect from ecu button and close the software...
